spyware problem?
Hi, when i load internet explorer, i always get this wierd site come up, i type another website in, but it wont go off this site, also i keep getting popups, i had this wierd thing in the taskbar that was like a yellow triangle with a ! mark then it was like a ball with spikes and went back, kept saying something about critical errors, i manage to remove that, but the ie problem with popups still happens, i dont even have any browser exept opera open now, and i still get them.
then website that it directs me to is http:// alliesecurity com/ obviously with a dot, just took it out so no one could load it, it seems to be some sort of information site that inform on threats, but its a spyware site.
I have ran hijack this, ad aware se and registry mechanic.
Oh and whilst i am on with this, AVG antivirus keeps telling me to restart in order for the update to be succesfull, yet i restarted loads, and it keeps saying it, whay is this happening?
~~EDIT**, thought i got rid of it, now another one is comign up, a yellow triangle that blinks all the time, with error message, screen shoes below:
http://img.photobucket.com/albums/v319/thehub/untitled-2.jpg
http://img.photobucket.com/albums/v319/thehub/AHHH.jpg
  1. Remove all the internet files from your computer including cookies n stuff…
  2. Check in your processes if thea is any process which you dont know, follow the path and delete from the destination…
  3. If AVG is not working for you then download AVAST Home Edition and run a thorough scan…
1: done that.
2:it is not showing in processes.
How about third suggestion?
nd just confirming, did u run those protection tools in Safe Mode? If not then do it…
yes, went and ran them in safe mode, i havent done the 3rd one yet, i am going to now, i downloaded another program called CC (CrapCleaner) that seems to have got rid of the blip thing again… but it comes back whenever i open IE.
Ok, done spyware thing too, still got wierd webpage, maybe upgrading to ie 7 will sort it?
Try NOT using IE … Try Firefox or K-Meleon
i dont use ie, but i still dont want the spyware to be there, maybe its ok if i dont use ie, but i still aint going to let this crap stay installed.
I always use Opera, as you can see in one of my above shots, i use opera, its the best browser there is.
