Ok, so i just bought a SATA SSD and and plugged it in and tried to install XP on it. I’m able to format it and start copying the install files, and it freezes at around 1 or 2% every time. I’m also not able to copy files onto in XP. I returned the drive and got a new one, and it does the same thing. I have a sata hard drive enclosure and the ssd works fine on that, i’m able to copy files and everything at ~10MB/s write speed. The manual to the ssd says it’s compatible with sata 1.5Gb/s, so i guess my question is, is it another bad SSD? Bad SATA controller on the motherboard? I can plug a regular platter SATA drive into the motherboard and it works fine. thanks for your help
I actually had a lot of trouble with this too. You need to make sure that the version of windows you are using has SP1 or higher on it already. Then you also need to slipstream your XP CD with the SATA install drivers.
it’s an xp sp3 disc… i can’t install ubuntu either, it freezes when copying files too
what are the computer specs?
Windows: Windows XP5.1 (Build 2600) Service Pack 3
Memory (RAM): 1280 MB
CPU Info: AMD Athlon™ 64 Processor 3700+
CPU Speed: 2404.0 MHz
Sound card: Realtek AC97 Audio
Display Adapters: NVIDIA GeForce 7950 GT
BIOS Info: AT/AT COMPATIBLE | 10/18/05 | A M I - 10000518
Motherboard: MSI MS-7151
If you have a version of SP 2 try and load that and see what happens. what are the specs on the SSD?
