My C Drive appears on the safely remove hardware icon in the bottom left hand side of my screen, surely this aint normal is it?
How do i change this?
If you have Windows installed on a SATA Hard Drive, then it’s normal ![]()
yip i do thanks
That’s strange, I have Windows XP on a SATA HDD and I don’t get that…
Yea, all 4 of my drives have that.
[QUOTE=Matt555]
Your not using XP Home are you?
Yeah, I am, XP Home - SP2
Is that why I don’t get that, because I’m using Home Edition?
Yes, i’m pretty sure it’s a Pro thing ![]()
yea im using pro, so that explains it.
