strange hardware entry
howdy folks, I have just re-installed XP after 2 years of virtually troublefree use.
All seemed fine until I opened up ‘My Computer’,I had an extre (scsi) dvd drive.
ON checking my hardware list I found an entry for SCSI and RAID controllers,despite not having any such hardware.
With systen restore turned OFF I deleted both entries (dvd rom and scsi controller) from the list, but each time I Boot up they have returned!!!:confused:
Can anyone enlighten me as to what the hell is going on??
Many thanks
eddie
Hardware= MSI M/B,Athlon,640megs memory,nvidia graphics,cd rom,cdrw,Belkin NIC,generic usb card,80gig HD
Do you have any drive emulation software running like Daemon Tools, or Nero something which could be making a virtual drive for you to load disc images? Usually that type of software makes the PC think that theres a SCSI drive.
[QUOTE=Addis]
No, Other than Nero burning rom software.
Open up device manager, find the selected scsi devices/hardware, right click and disable. It’s probably drive emulation software you installed like Alcohol 120%, etc.
