Strange Problem
Yesterday i noticed that with radlinker my Core and memory clocks of the GPU are set to 0 which can be possible:mad:when i try to set his defeault clocks radlinker will set 0???:confused:also i noticed that the same problem happens with ati tool!!!WTF!!
First of all, this should be in the video card forum. But anyways, it isn’t actually at zero, the software is just having issues detecting the speed. Think about it, if the clocks were at zero then the computer would have no video. I would recommend that you make sure the OC utilities are up to date and that the gfx drivers are also up to date.
