I’m trying to get the last screw out of a motherboard that’s holding it in a case, but there’s something wrong with it. I can turn it fine, but it seems to reset after a few turns and be back where it was before I turned it at all. I’m guessing there’s a problem with the threads.
Does anyone have a suggestion for getting it out? Is it okay to cut into the motherboard to pull it out if there’s no circuitry along the cutting path?
