Super High 'CPU Usage' Help pls
Hi, Ill say the situation.
-First off im getting 100% CPU Usage, on desktop… wtf… but heres a little brief of whats up-
My Main PC broke, so i got some parts fixed. But kept the main parts, like Mobo, Harddrive, Power Supply… but my gfx (powercolor 9800 pro) broke, so i got rid of that.
SO i made a new computer out of old bits, not using any of these ones. and bought myself a nice new 9800 pro Atlantis - sapphire.
Then, i got my stuff back from my main PC, and decided to rebuild my main PC. I put in this new 9800 pro, had some usul problems, like Hardrive installing, XP, and the usual blue screen of death sh!t.
But i fixed that, got into XP, installed some games, drivers -Sound, GFX (new ATI ones) SP1+1a / 2 and standard drivers.
But on my game World Of warcraft, i ‘Tried’ to play… i was getting 1fps.. and it isnt net lag, its graphics lag. I know this gfx card is good, and is working, as it was in my other pc, and running nicely and quickly. I cant find anythign else to do. Done reinstalling game, and drivers, and .net… previous drivers, driver cleaner…
ill list my processes, theres nothing wrong with what im seeing…
Explorer.exe - 15k
Firefox.exe -24k
isafe.exe -7k
Isass.exe -1k
Services.exe -3k
Smss.exe -.3k
Soundman.exe -2k
Spoolsv.exe -5k
Svchost.exe -5k
Svchost.exe -3k
Svchost.exe -4k
Svchost.exe -8k
ctfmon.exe -2k
csrss.exe -3k
system -.2k
System Idle Process .02k
vsmon.exe (Zonealarm btw) -15k
Winlogon.exe -.8k
Zlclient.exe -3k
—86% CPU Usage
Pysical Memory(K)
-Total 1048052
  • Available 807640
    -System Cache 529088
— When i first built this PC, i was barely getting over 30% cpu usage on games… and wtf… need help, otherwise im gunna reinstall, / chuck this out the Window… then Kill Bill gates, and buy a Mac
No need to double post - http://www.hardwareforums.com/showpost.php?p=37013&postcount=2 (post now deleted)
Hi there,
No need to kill anyone. And you needn’t buy a Mac either.
If data is not a problem, then format the HDD; better still, backup you data files (data files only, mind you) and then format. Reinstall Windows and all the other stuff ie. graphics drivers, lan, sound etc. except the following: no service packs, Windows or Internet Explorer please! Also see that all power saving modes are switched off in Display properties/Screen Saver/Power. Also, disable Display Power Management in the BIOS. Install your games and run. Of course, the latest version of DirectX should be installed.
Good luck.
Chinmoy
