system usage apps?
Hi, sorry if its hard to understand, finding it hard to explain :stuck_out_tongue:
Is there any software that can find out all the resources I am using, like amount or ram, cpu usage/temperature at startup when the desktop first appears, then do it again, when you got some programs on, and also do this once every day on startup and say when program is running, then as time went on, and as windows came to end of its life needing a fresh install, I could see how the system resources and thigns like that have gone down.
So what I mean is, any program to compare system resources usage like cpu and memory and amount of programs starting up at startup by a fresh install, and then old install, you know, maybe about 3 months down the line.
This is the thing I love about Windows - the way it bloats over the course of a few months :smiley:
I think theres a performance monitor tool under Computer Management.
I’m hoping Micosoft’s BootVis is what your looking for. Run this tool and will asses your computers boot time etc and will display system graphs including CPU usage, Disk access, Boot activity and driver delay. Run this tool as often as you need and then, at the end of three months you can compare the results.
cheers man, sounds like the right tool for me :smiley:
