thanks newegg for not telling me stuff.
http://www.newegg.com/Product/Product.asp?Item=N82E16819103537
http://www.newegg.com/Product/Product.asp?Item=N82E16819103536
what’s the difference?
I see cores voltages are different.
Retail/OEM:), I have no idea why the voltage is different though.
The second one has integrated into chip FSB. BTW, kick*** sig EX.
I thought all A64 chips did? Thanks Max:)
I’d go for the first one. Its retail so you’ll get a warranty and a lower core voltage will probably mean when you oc, you’ll be able to put the voltage up ok without killing your CPU.
Well I notcied that the first says 1 GHz FSB and the second says integrated into chip. I didn’t look past that.
