The Sims shuts down! Help!
Please Help! My daughter loves to play the Maxis/Electronic Arts game The Sims. However, all of the sudden, the program suddenly started to shut itself down after it was booted up. The Sims is running on an IBM PC with Windows 2000 Professional. It has the Livin’ Large and Unleashed Expansion Packs installed. It was running fine for a week or two and then all of the sudden, once she started the program running, it would get to the Neighborhood screen and then it would shut down (turn itself off) and stop, returning to the Windows desktop. I have tried uninstalling and reinstalling the Sims program. I even went so far as to delete Windows, reformat C: drive and reinstall Windows again. It hasn’t solved the problem. Has anyone run into this problem or has any idea what is causing it or how to fix it? Thank you for any help you can be.
Try installing the latest drivers for your video
You might also want to check your event logs for errors. Open Control Panel —>Administrative Tools —>Computer Management—>Event Viewer.
