Hi everyone
I am sick and tired of the noise my system make.
Honestly it is not that bad but it is annoying to me…
I have a freezer S478 which is damn near silent but then I have two 80mm fans blasting away. Add the slight humm from the drives and you end up with this apparent background noise. :mad: Also I have problem with air circulation as, lets face it, my current case is :swear: :swear: ! (first rymes with drunken and the second with meat…
I found this case - http://www.thermaltake.com/xaserCase/soprano/bns/bns.htm
which looks awsom, but is it? Will it have loads of space for air to move arround and drown the noises? It sells in the UK for about £50 excluding shipping. What do you guys recon? Will it be as good as it looks? It boasts two silent 120mm fans and one 90mm side fan. Also other neet stuff like tooless drive rack etc.
Thanks for your comments.
