Thinkpad HELP
Hi everyone,
I am trying to upgrade the memory on a very old laptop, its an IBM ThinkPad 380ED. I have installed 64mb of RAM, and the laptop is still showing 48mb. What do I do to have my laptop run with more RAM? Flash the BIOS? And how do I do that?
Thanks for any help,
Some motherboards have a memory limitation, and in that case a BIOS flash is helpful in some cases and not others, depending on the motherboard. If there is a BIOS update at all for a laptop that old, I’d apply it. They were usually pretty big fixes on those old Thinkpads if they released them at all. In other cases of course, the hardware itself is limited to a certain clip and that’s it. Also, some RAM is high-density, and some motherboards cannot properly utilize high-density RAM. In that case you would only be able to utilize a portion of the RAM - the portion the motherboard recognizes. That is also a hardware limitation that cannot be worked around (aside from replacing it with low-density RAM).
P.S. - Just out of sheer curiosity, what OS are you running on that bad boy?
-AT
[QUOTE=Anti-Trend]
Some motherboards have a memory limitation, and in that case a BIOS flash is helpful in some cases and not others, depending on the motherboard. If there is a BIOS update at all for a laptop that old, I’d apply it. They were usually pretty big fixes on those old Thinkpads if they released them at all. In other cases of course, the hardware itself is limited to a certain clip and that’s it. Also, some RAM is high-density, and some motherboards cannot properly utilize high-density RAM. In that case you would only be able to utilize a portion of the RAM - the portion the motherboard recognizes. That is also a hardware limitation that cannot be worked around.
-AT
This laptop is running Windows ME, I have been told this laptop can run a maximum of 80mb.
