Upgrade advice and infomation
hi all
I’am thinking to upgrade my system but not sure what to get for peformance?
this is what i was thinking for my graphic card the XFX GEFORCE 7800GTX but not sure what motherboard, powersupply and ram to get with this card? (if necessery)
http://www.ebuyer.com/customer/products/index.html?action=c2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=92419
if there any other better cards coming out in the next 2 months can you please say..:stuck_out_tongue:
<<<<—infomation about my current setup
if anything else is needed please ask
First of all, you definetly wont be able to use your current motherboard with that card since the card is PCI express and your motherboard doesn’t support that. If you’re planning on keeping as much hardware as possible and just adding the video card then, depending on the PSU, you should just have to replace the motherboard.
As far as a new motherboard, something like this → http://www.newegg.com/Product/Product.asp?Item=N82E16813128287 should do you fine (although someone else might be able to show you a better one).
Lastly, what are the specs of the current PSU in your system?
my PSU is this one but in 400watts
http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=271185
also what do you think of this board? http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=213213
would this support SLI and 184-pin memory?
While the Fortron is good, it may not be enough to run an SLI rig. It certainly wouldn’t hurt to try, but you’d do well to budget for a new unit. The Tagan 480W unit is known to be a solid unit (the FSP —Fortron— is a very good company, but may not be made to handle what you’re looking to run) as well as the Hiper 480-500W+ units…
All new Intel-based motherboards use 240-pin DDR2 RAM. If you want to keep your 184-pin DDR, you’ll have to not get SLI or go over to an AMD-based system. Or purchase new RAM. You will not find any Intel-based motherboard supporting DDR and SLI.
If I were you I’d stick with what you have and pop in a nice X800XT, http://www.newegg.com/Product/Product.asp?Item=N82E16814142038 I don’t think it’s very economical to buy a whole new motherboard and video card that would be bottlenecked by the CPU anyway. This one performs very well and saves you the expensive of a pricey upgrade.
thanks guys i will have a think about the choices i have i let you know what i will do :wink:
