Hello all. Been a while since my last visit here when I built my last beast. However, the time has come to consider updating.
I want to use as many components from my last build as possible. Take a look on my computer in the profile. I do want to replace processor, Memory and Motherboard and also the case. I would also like to make my PC a little quiter than before. Too many fans!
My use is 40% internet, 50%games and 10% MS Office stuff. I’ve got £400GBP to spend - maybe a little more.
Processor, Motherboard and suitable memory - something AMD and 64bit. I had real problems getting the right memory sorted out last build for the Asus board. I don’t want overclocking and want something that won’t crash.
Case - I want it black and full tower. It’s not going anywhere so weight isn’t an issue.
Cooling, speed & quietness are the main considerations.
Well, a few other things you should factor in (your plan is still do-able) is that AGP video cards are going the way of the dodo, due to the PCI Express interface which will eventually replace PCI, PCI-X, and AGP slots. Secondly, the power requirements of newer systems are higher, so unless you’ve got a good 480W or better unit, I would highly recommend replacing the unit you have. Having said that, here’s what I came up with off eBuyer:
However, seeing as you have a Geforce 6800, you might simply upgrade to 1GB of RAM and change out your fans for a some Vantec Stealth ones.
To be blunt, if you’re going to upgrade to an Athlon64, you’re better off long-term by going with a PCIe-based graphics. Don’t look at the motherboards with both PCIe and AGP, as the AGP slot is plugged into the PCI bus, and that will kill your performance. The sole exception would be a motherboard using a ULi chipset, since ULi has a chipset out natively supporting PCIe and AGP.
A CPU upgrade is nice, but if you’re not willing to switch over to a PCIe-based A64 box, you’re much better off upgrading to 1GB and going with low speed fans (or even watercooling) to cope with the sound.
yes thats sound pretty solid i just built my rig, which is my current pc under my computer and it was 1,500 us dollars and some change, one good question would be do you have an favorites for manufactures, also i might recamend a little better graphics card something in the 7 series for nvdia at least
