Hi. I am planning to upgrade my PC. More like overhaul it. ![]()
These are the components that I am planning to buy:
Intel Core 2 Duo E6300 (1.86 GHz) / E6400 (2.13 GHz)
Asus P5B - VM (Intel G965 / ICH8, 1066 / 800 / 533 MHz, 4 x DIMM, max. 8GB, DDR2 800* / 667 / 533 MHz, non-ECC, un-buffered memory, ESATA and IEEE 1394 Support, Intel® GMA X3000, Intel® Clear Video Technology)
Kingston 1GB 800 MHz
Samsung 250GB 7200 rpm SATA
These are the components that I’ll be transferring from the old PC to the new one:
- Sony DVD Burner
- Creative CD-ROM
- Asus DVD-ROM
- Sony Floppy drive
Everything else goes.. in the trash bin. I am not sure if I missed something important regarding the things that I am going to buy. Here are some questions that are bothering me.
Are the components compatible with one another? I really have no idea in building this up.
What I am after is a Firewire port for the Handycam. Once I have a Firewire port, can I plug the Handycam and edit movies right away or do I need to have another hardware component such as cards?
Is it ok not to use a video card give these specs?
Is it ok to use a microATX board in an ATX casing? The computer store only has P5B-VM, which is microATX. Just in case the ATX counterpart of the P5B is available, are the specs good? Or does this board have issues?
What PSU do I need? I have just encountered this term recently, I thought that all PSU’s come hand in hand with the case, like a package.
By the way, I will be using Windows XP Pro.
Thank you for reading.![]()
