USB memory stick and Win ME
Hey all
I need to move some stuff from a Win ME PC to another. The total size unfortunately is larger than a floppy drive so I want to put the lot on my USB drive. Are there generic drivers for USB sticks or are the drivers specific to each device make and model?
Cheers!! :cool:
[QUOTE=sabashuali]
no, everything that is required is already installed into Win98 SE & above[ot]just plug the pen into the USB & it will be detected, officially on Win ME your supposed to select remove the item from systray but i never did, i just pulled it out & let Win have another error message[/ot]
Edit: all USB pens are generic
You should just need the USB Mass Storage driver, but I’m not sure if its included in ME.
[QUOTE=Addis]
yes it is, i think it is automaticlly installed on first insert, but it could already be in there
Thanks guys! I will give it a go.
Just to be on the safe side, I will take two types, 256MB stick and a 2GB one.
Hopefully one will work.
Good ol’ win ME hey? :cool:
