usb problems
hi im a newbie just hoplng to get some knowledge i have a problem the 2,:doh: USBports on the front of my commie have stopped working my other USBS are working ok any help would be much appreciated thanks :doh:
hello there, doesnt seem to be a big problem, just a case of getting inside yourpc, the front USB ports connect straight to your mainboard inside your case via small cables running through your case.
Go inside your case, there should be a cable like the one shown below in the link below. this cable would have come lose, simply re-connect it back on to the motherboard connection, if you cant find it tell me the name of your mobo and ill locate it for you hope this helps :slight_smile:
FRONTX - USB Internal Cable - connect to motherboard header (pinout)
thanks will have a look soundw easy enough appreciate your help:D
