Hi! Does anyone know why I have lost the option to switch between windows users, we have 5 users on my pc but since I installed a PC card for my wireless connection I can no longer access the other users.
go to Control Panel → User Accounts → Click on “Change the way users log on or off” → Use Fast User Switching (make sure its ticked)
it will not let me change it , it says i have got uninstall the wi-fi device to be able to change it but i need the wi-fi adapter.
You may have a problem with your registry .. to be specific it is a problem with ‘msgina.dll’. This is because the new WiFi software modifies this DLL, so restoring it back to the original should fix your problem..
Please download & visit:
XP_FixLogon.zip
The Default Windows Logon Interface May Not Appear After Installing Third-Party Program
For more information and fixes of your problem!
Is it safe to make this alteration to the registry or could it cause problems?
It is safe, but [COLOR=“Red”]always make a backup before you make modifications (sorry I should have included that in my post!).
In Regedit navigate to File > Export and save it to a place such as desktop!
Thanks,that seems to have done the trick.
Regards
Wayne
Ok great!
I was glad to help you!
