Hi.
I have already been writing on other forum about that problem, but nobody can help me there.
I have recently built a computer, here are spec:
CPU: INTEL CORE 2 QUAD Q6600 2.4 GHZ
Mainboard: Gigabyte GA-EP31-DS3L
Memory: KINGSTON HYPERX PC8500 DDR2 1066 2GB (2x1GB)
GPU: XFX XFX NVIDIA GeForce 9600 GT 512MB GDDR3 PCI-Express 2.0 - PV-T96G-YHF4
PSU: T/TAKE W0093 PSU 500W TR2-500W RET
WiFi: NETGEAR WN311B RangeMax NEXT
DVD: LG 20x DUAL LAYER DVD RW SATA DRIVE INTERNAL BURNER
HDD: Some Hitachi 500GB SATA3 (model is not relevant in that case i think)
That is all I have conected+ keyboard, mouse and 3 additional fans to cool down the system.
Now, everything is working OK, I have installed Windows XP Prof SP3, downloaded latest patches, installed latest drivers for everything.
Now it gets to the trouble. I have installed Guild Wars, tried to run them. The game downloaded patches, installed them, i logged in to my accocunt, picked the character, tried to log in to the game. As soon as logging in to the game finished and i supposed tto see my char in a city/town, I could hear graphics card fan starting working on very high speed, my monitor went black and I could see message from monitor “No signal input” (there was no signal from graphics to monitor). Keyboard was not working, I had to reset PC.
Second try, exactly the same situation.
So I decided to try other game. I have installed Assassins Creed, quite a new game, more system req than GW. I turned it on, started playing, was able to play for like 30miinutes before my screen went black again (I was playing on highest detail and resolution). I have tried Assassins Creed few times, every time I was able to play as much as I want, and I was getting the black screen only when I entered one room in the mission. Then I tried to enter that room from differennt side and it was ok, the game continued. I got black screen later on in different mission and different place again.
So I tried Warhammer Online, the same situation as with Guild Wars, I was able to log in to character select, pick character, but I wasn’t able to log in to the game and play.
I have tried Devil May Cry 2 for like 30min, it was ok, i haven’t tried it again.
I decided to check the hardware and software. I runned 3dmark05_v130, runned the test. First animation 3d in the program- black screen. Happend every time I have runned it.
I have downloaded speedfan to check temperatures, fan speeds and voltage. But nothing is wrong. GPU temp did not go above 62deg C, never. CPU temp was 35-42deg C. Voltages ok, fan speeds ok.
Now is what I know, checked and tried so far:
-when I plugged ATI hd3850 instead my GF, Guild Wars were working perfect;
-my PSU has two +12V rails, one with 15Amps and second with 16Amps, I heard my graphics (GeForce 9600GT) need about 26Amps on +21V rail, but it is not confirmed
-i havee tried drivers 180.48 as well as 181.20, on both the same problem;
-all my cables are secured (not loose), the airflow in the case is good;
-I have tested my PC with some application from Guild Wars, here is some output, which I think might be important:
System Information
Time of this report: 1/15/2009, 18:50:03
Machine name: SPEEDFIRE
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp.080413-2111)
Language: English (Regional Setting: English)
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: EP31-DS3L
BIOS: Award Modular BIOS v6.00PG
Processor: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz (4 CPUs)
Memory: 2046MB RAM
Page File: 301MB used, 3637MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 9600 GT
Manufacturer: NVIDIA
Chip type: GeForce 9600 GT
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0622&SUBSYS_23621682&REV_A1
Display Memory: 512.0 MB
Current Mode: 1360 x 768 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0011.7116 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 1/3/2008 14:26:00, 5885696 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 1/3/2008 14:26:00, 7077344 bytes
Device Identifier: {D7B71E3E-4562-11CF-FE6E-690300C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0622
SubSys ID: 0x23621682
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
I have no idea what is wrong (probably just faulty graphics?).
Any help would be apreciated.
Thanks in advance.
Daniel.
