:good: By accident while installing my ati all in wonder 9700 pro i kinda pulled out the power plug connected to the vid card and it bent the pinns real bad.. but i straightened them out pretty good with the pinn and it fit perfectly and i dont notice any discrupinsances… u think i caused any harm, or is it a good peice of technology!!! :good: :good: :good:
Name some things that coulda happened..
Its not perfectly even but good enough..
If it still works then no i gess you did not pull the pins out to far you should have no problems but if you see a decrease in the performance of the card then you might have a problem. The only thing that i think could happen is when you bent the power pins they might be a little losse. This would cause power lose to the card so you might see a decrease in the performance in it.
