A Nvidia GeForce MX 4000 pci-e BFG TECH
I put a jumper on the fan power supply and I think it burned one of the teeth and since then my computer won’t recognize it and I can’t use it as my display device. If there is a way to fix this without sending it in for a replacement I would really like to know. The touth on the bottom far right is a sark silver color
[QUOTE=Aroshin]
exactly what is the problem ?
Umm it’s stated in the first post it doesn’t work the computer doesn’t recognize it’s connected
sorry, i scan read again,
lets start again, a bit more info would be helpful
what are your specs ?
and O/S ?
sighs it’s not the computer it’s the videocard nothing is wrong with the computer it’s recognized the thing before I just want to know if their is a way to fix the “Teeth” on the video card
by saying “Teeth” do you mean the contacts (where the graphics card connects to the mobo)
yea I don’t use the same terms as other people lol I’m from kentucky in a small town we basically have our own langauge
don’t worry over it i have also invented my own langguage, you may be able to bod-j it by glueing tin foil or something on it, lol, but beyond that, you have a very pretty paperweight there
upon checking the ohms of the chip I found out the thing is still conduction across the burn
Maybe it’s really a problem with the computer Compaq presario S4020wm basically everything is factory the video card is the only real enhnacement
I don’t know why it isn’t working help would be greatly appreciated and I can describe what happened in detail if needed
i don’t know but maybe the problem is with the socket not your card, can you get hold of some spray air to blow dust off everything
I ust did and cleaned it with a brush and toothpic
sounds like you’ve been deyalying the inevitable, unfortunatly unless you can bod-j it you’ll have to get a new grfx card
