I just installed a new video card, but everytime I turn on my computer, I get an error message stating the there is no video card installed or there is no driver for this card. Can someone please tell me if my configurations are correct? Do I need to change anything in BIOS?
I have attached a report for your review:
--------[ Summary ]-----------------------------------------------------------------------------------------------------
Computer:
Operating System Microsoft Windows XP Professional
OS Service Pack Service Pack 2
Internet Explorer 6.0.2900.2180
Computer Name HOME
User Name Admin
Logon Domain HOME
Motherboard:
CPU Type Intel Pentium 4A, 2666 MHz (5 x 533)
Motherboard Name ECS 661FX-M (Deluxe) (3 PCI, 1 AGP, 1 CNR, 2 DIMM, Audio, Video, LAN)
Motherboard Chipset SiS 661FX
System Memory 1024 MB (DDR SDRAM)
BIOS Type Award (06/18/04)
Communication Port Communications Port (COM1)
Communication Port Communications Port (COM2)
Communication Port ECP Printer Port (LPT1)
Display:
Video Adapter RADEON 9600 SERIES - Secondary (256 MB)
Video Adapter RADEON 9600 SERIES (256 MB)
3D Accelerator ATI Radeon 9600 (RV350)
Multimedia:
Audio Adapter SiS 7012 Audio Device
Storage:
Floppy Drive Floppy disk drive
Disk Drive WDC WD800BB-00CAA1
Optical Drive LITE-ON LTR-52246S (52x/24x/52x CD-RW)
Partitions:
C: (NTFS) 49999 MB (39891 MB free)
--------[ DMI ]---------------------------------------------------------------------------------------------------------
[ BIOS ]
BIOS Properties:
Vendor Phoenix Technologies, LTD
Version 6.00 PG
Release Date 06/18/2004
Size 512 KB
Boot Devices Floppy Disk, Hard Disk, CD-ROM, ATAPI ZIP, LS-120
Capabilities Flash BIOS, Shadow BIOS, Selectable Boot, EDD
Supported Standards DMI, APM, ACPI, PnP
Expansion Capabilities ISA, PCI, AGP, USB
[ System ]
System Properties:
Manufacturer SiS Technology Inc.
Product SiS661FX + SiS964
Wake-Up Type Power Switch
[ Motherboard ]
Motherboard Properties:
Manufacturer http://www.abit.com.tw
Product SG72(SIS 661FX-964L)
Version V1.0
[ Chassis ]
Chassis Properties:
Chassis Type Desktop Case
[ Memory Controller ]
Memory Controller Properties:
Error Detection Method None
Error Correction None
Supported Memory Interleave 1-Way
Current Memory Interleave 1-Way
Supported Memory Types DIMM, SDRAM
Supported Memory Voltages 3.3V
Maximum Memory Module Size 1024 MB
Memory Slots 2
[ Processors / Intel(R) Pentium(R) 4 CPU ]
Processor Properties:
Manufacturer Intel
Version Intel(R) Pentium(R) 4 CPU
External Clock 133 MHz
Current Clock 2666 MHz
Type Central Processor
Voltage 0.0 V
Status Enabled
Upgrade ZIF
Socket Designation Socket 478
[ Caches / Internal Cache ]
Cache Properties:
Type Internal
Status Enabled
Operational Mode Write-Back
Maximum Size 20 KB
Installed Size 20 KB
Supported SRAM Type Synchronous
Current SRAM Type Synchronous
Socket Designation Internal Cache
[ Caches / External Cache ]
Cache Properties:
Type External
Status Enabled
Maximum Size 512 KB
Installed Size 512 KB
Socket Designation External Cache
[ Memory Modules / A0 ]
Memory Module Properties:
Socket Designation A0
Type DIMM, SDRAM
Installed Size 512 MB
Enabled Size 512 MB
[ Memory Modules / A1 ]
Socket Designation A1
Type DIMM, SDRAM
Enabled Size 512 MB
[ Memory Devices / A0 ]
Memory Device Properties:
Form Factor DIMM
Type SDRAM
Type Detail Synchronous
Size 512 MB
Total Width 64-bit
Data Width 64-bit
Device Locator A0
Bank Locator Bank0/1
[ Memory Devices / A1 ]
Form Factor DIMM
Type SDRAM
Size 512 MB
Total Width 64-bit
Data Width 64-bit
Device Locator A1
Bank Locator Bank2/3
[ System Slots / PCI0 ]
System Slot Properties:
Slot Designation PCI0
Type PCI
Usage Empty
Data Bus Width 32-bit
Length Long
[ System Slots / PCI1 ]
Slot Designation PCI1
Type PCI
Usage Empty
Length Long
[ System Slots / PCI2 ]
Slot Designation PCI2
Type PCI
Usage Empty
Length Long
[ System Slots / PCI3 ]
Slot Designation PCI3
Type PCI
Usage In Use
Length Long
[ System Slots / AGP ]
Slot Designation AGP
Type AGP
Usage Empty
Length Long
[ Port Connectors / PRIMARY IDE ]
Port Connector Properties:
Internal Reference Designator PRIMARY IDE
Internal Connector Type On-Board IDE
External Connector Type None
[ Port Connectors / SECONDARY IDE ]
Internal Reference Designator SECONDARY IDE
[ Port Connectors / FDD ]
Port Type 8251 FIFO Compatible
Internal Reference Designator FDD
Internal Connector Type On-Board Floppy
[ Port Connectors / COM1 ]
Port Type Serial Port 16450 Compatible
Internal Reference Designator COM1
Internal Connector Type 9 Pin Dual Inline (pin 10 cut)
External Connector Type DB-9 pin male
[ Port Connectors / COM2 ]
Internal Reference Designator COM2
[ Port Connectors / LPT1 ]
Port Type Parallel Port ECP/EPP
Internal Reference Designator LPT1
Internal Connector Type DB-25 pin female
External Connector Type DB-25 pin female
[ Port Connectors / Keyboard ]
Port Type Keyboard Port
Internal Reference Designator Keyboard
Internal Connector Type PS/2
External Connector Type PS/2
[ Port Connectors / PS/2 Mouse ]
Port Type Mouse Port
Internal Reference Designator PS/2 Mouse
[ Port Connectors / USB0 ]
Port Type USB
Internal Connector Type None
External Reference Designator USB0
--------[ Sensor ]------------------------------------------------------------------------------------------------------
Sensor Properties:
Sensor Type ITE IT8705F
Sensor Access ISA 290h
Temperatures:
Motherboard 28 °C (82 °F)
Aux 21 °C (70 °F)
Cooling Fans:
CPU 2312 RPM
Voltage Values:
CPU Core 1.47 V
+2.5 V 2.64 V
+3.3 V 3.26 V
+5 V 5.05 V
+12 V 11.01 V
+5 V Standby 5.05 V
VBAT Battery 3.06 V
Debug Info 5C A5 CC BC AC D6 CF BC BF 15 1C C9 (47)
--------[ CPU ]---------------------------------------------------------------------------------------------------------
CPU Properties:
CPU Alias Northwood, A80532
CPU Stepping D1
Original Clock 2667 MHz
L1 Trace Cache 12K Instructions
L1 Data Cache 8 KB
L2 Cache 512 KB (On-Die, ATC, Full-Speed)
CPU Physical Info:
Package Type 478 Pin uPGA
Package Size 3.50 cm x 3.50 cm
Transistors 55 million
Process Technology 6M, 0.13 um, CMOS, Cu, Low-K
Die Size 131 mm2
Core Voltage 1.475 - 1.55 V
I/O Voltage 1.475 - 1.55 V
Typical Power 38.7 - 82 W (depending on clock speed)
Maximum Power 49 - 103 W (depending on clock speed)
CPU Manufacturer:
Company Name Intel Corporation
Product Information http://www.intel.com/products/browse/processor.htm
CPU Utilization:
CPU #1 0 %
--------[ CPUID ]-------------------------------------------------------------------------------------------------------
CPUID Properties:
CPUID Manufacturer GenuineIntel
CPUID CPU Name Intel(R) Pentium(R) 4 CPU 2.66GHz
CPUID Revision 0F29h
IA Brand ID 09h (Intel Pentium 4A)
Platform ID 0Fh (Socket 478)
IA CPU Serial Number Unknown
Instruction Set:
IA MMX Supported
IA SSE Supported
IA SSE 2 Supported
IA SSE 3 Not Supported
CLFLUSH Instruction Supported
CMPXCHG8B Instruction Supported
CMPXCHG16B Instruction Not Supported
Conditional Move Instruction Supported
FEMMS Instruction Not Supported
MONITOR / MWAIT Instruction Not Supported
CPUID Features:
36-bit Page Size Extension Supported
Advanced Cryptography Engine Not Supported
Alternate Instruction Set Not Supported
Automatic Clock Control Supported
CPL Qualified Debug Store Not Supported
Debug Trace Store Supported
Debugging Extension Supported
Enhanced SpeedStep Technology Not Supported
Fast Save & Restore Supported
Fast System Call Supported
Hyper-Threading Technology Not Supported
L1 Context ID Supported
Local APIC On Chip Supported
LongRun Not Supported
LongRun Table Interface Not Supported
Machine-Check Architecture Supported
Machine-Check Exception Supported
Memory Type Range Registers Supported
Model Specific Registers Supported
No-Execute Page Protection Not Supported
Page Attribute Table Supported
Page Global Extension Supported
Pending Break Event Supported
Physical Address Extension Supported
Processor Duty Cycle Control Supported
Processor Serial Number Not Supported
Random Number Generator Not Supported
Self-Snoop Supported
Thermal Monitor Supported
Thermal Monitor 2 Not Supported
Time Stamp Counter Supported
Virtual Mode Extension Supported
--------[ Motherboard ]-------------------------------------------------------------------------------------------------
Motherboard ID 06/18/2004-SiS-661-6A7I4E1AC-13
Front Side Bus Properties:
Bus Type Intel NetBurst
Bus Width 64-bit
Real Clock 133 MHz (QDR)
Effective Clock 533 MHz
Bandwidth 4266 MB/s
Chipset Bus Properties:
Bus Type SiS MuTIOL
Bus Width 16-bit
Motherboard Physical Info:
CPU Sockets/Slots 1
Expansion Slots 3 PCI, 1 AGP, 1 CNR
RAM Slots 2 DIMM
Integrated Devices Audio, Video, LAN
Form Factor Micro ATX
Motherboard Size 230 mm x 240 mm
Motherboard Chipset SiS661FX
Motherboard Manufacturer:
Company Name Elitegroup Computer Systems
Product Information http://www.ecs.com.tw/products/pd_list.asp?submenu_id=4&function_id=1
BIOS Download http://www.ecs.com.tw/download/dw_list.asp?submenu_id=23&function_id=1
--------[ Memory ]------------------------------------------------------------------------------------------------------
Physical Memory:
Total 1023 MB
Used 234 MB
Free 789 MB
Utilization 23 %
Swap Space:
Total 2462 MB
Used 132 MB
Free 2329 MB
Utilization 5 %
Virtual Memory:
Total 3485 MB
Used 366 MB
Free 3119 MB
Utilization 11 %
--------[ Chipset ]-----------------------------------------------------------------------------------------------------
Chipset Properties:
CAS Latency 2.5T
RAS To CAS Delay 3T
RAS Precharge 3T
RAS Active Time 6T
Memory Slots:
DRAM Slot #1 512 MB (DDR SDRAM)
DRAM Slot #2 512 MB (DDR SDRAM)
AGP Properties:
AGP Version 3.05
AGP Status Enabled
AGP Aperture Size 128 MB
Supported AGP Speeds 1x, 2x, 4x, 8x
Current AGP Speed 8x
Fast-Write Not Supported
Side Band Addressing Supported, Enabled
Chipset Manufacturer:
Company Name Silicon Integrated Systems Corporation
Product Information http://www.sis.com/products/index.htm#chipsets
Driver Download http://download.sis.com/index_step1.php
--------[ BIOS ]--------------------------------------------------------------------------------------------------------
BIOS Properties:
BIOS Type Award
Award BIOS Type Phoenix - AwardBIOS v6.00PG
Award BIOS Message Phoenix - AwardBIOS v6.00P
System BIOS Date 06/18/04
Video BIOS Date 04/01/15
BIOS Manufacturer:
Company Name Phoenix Technologies Ltd.
Product Information http://www.phoenix.com/en/products/default.htm
--------[ Windows Video ]-----------------------------------------------------------------------------------------------
[ RADEON 9600 SERIES - Secondary ]
Video Adapter Properties:
Device Description RADEON 9600 SERIES - Secondary
Adapter String RADEON 9600 SERIES
BIOS String BK-ATI VER008.015.058.000
Chip Type RADEON 9600 Series AGP (0x4150)
DAC Type Internal DAC(400MHz)
Installed Drivers ati2dvag (6.14.10.6444)
Memory Size 256 MB
Video Adapter Manufacturer:
Company Name ATI Technologies Inc.
Product Information http://www.ati.com/products/home-office.html
Driver Download http://www.ati.com/support/driver.html
[ RADEON 9600 SERIES ]
Memory Size 256 MB
--------[ PCI / AGP Video ]---------------------------------------------------------------------------------------------
ATI Radeon 9600 (RV350) Video Adapter
ATI Radeon 9600 (RV350) 3D Accelerator
--------[ GPU ]---------------------------------------------------------------------------------------------------------
Graphics Processor Properties:
Video Adapter ATI Radeon 9600 (RV350)
GPU Code Name RV350
PCI Device 1002 / 4150
Transistors 76 million
Process Technology 0.13u
Bus Type AGP
Memory Size 256 MB
GPU Clock 392 MHz
RAMDAC Clock 400 MHz
Pixel Pipelines 4
TMU Per Pipeline 1
Vertex Shaders 2 (v2.0)
Pixel Shaders 1 (v2.0)
DirectX Hardware Support DirectX v9.0
Pixel Fillrate 1568 MPixel/s
Texel Fillrate 1568 MTexel/s
Memory Bus Properties:
Bus Type DDR
Bus Width 128-bit
Real Clock 202 MHz (DDR)
Effective Clock 404 MHz
Bandwidth 6464 MB/s
Graphics Processor Manufacturer:
--------[ Desktop ]-----------------------------------------------------------------------------------------------------
Desktop Properties:
Device Technology Raster Display
Resolution 1024 x 768
Color Depth 32-bit
Color Planes 1
Font Resolution 96 dpi
Pixel Width / Height 36 / 36
Pixel Diagonal 51
Vertical Refresh Rate Default
Desktop Wallpaper C:\WINDOWS\web\wallpaper\Bliss.bmp
Desktop Effects:
Combo-Box Animation Enabled
Drop Shadow Effect Enabled
Flat Menu Effect Enabled
Font Smoothing Enabled
Full Window Dragging Enabled
Gradient Window Title Bars Enabled
Hide Menu Access Keys Enabled
Hot Tracking Effect Enabled
Icon Title Wrapping Enabled
List-Box Smooth Scrolling Enabled
Menu Animation Enabled
Menu Fade Effect Enabled
Minimize/Restore Animation Enabled
Mouse Cursor Shadow Enabled
Selection Fade Effect Enabled
ShowSounds Accessibility Feature Disabled
ToolTip Animation Enabled
ToolTip Fade Effect Enabled
Windows Plus! Extension Disabled
--------[ Multi-Monitor ]-----------------------------------------------------------------------------------------------
\\.\DISPLAY1 Yes (0,0) (1024,768)
--------[ Windows Audio ]-----------------------------------------------------------------------------------------------
midi-out.0 0001 0066 Microsoft GS Wavetable SW Synth
mixer.0 FFFF FFFF Realtek AC97 Audio
wave-in.0 FFFF FFFF Realtek AC97 Audio
wave-out.0 FFFF FFFF Realtek AC97 Audio
--------[ PCI / PnP Audio ]---------------------------------------------------------------------------------------------
SiS 7012 Audio Device PCI
--------[ Windows Storage ]---------------------------------------------------------------------------------------------
[ Floppy disk drive ]
Device Properties:
Driver Description Floppy disk drive
Driver Date 7/1/2001
Driver Version 5.1.2600.0
Driver Provider Microsoft
INF File flpydisk.inf
[ WDC WD800BB-00CAA1 ]
Device Properties:
Driver Description WDC WD800BB-00CAA1
Driver Version 5.1.2535.0
INF File disk.inf
Device Manufacturer:
Company Name Western Digital Corporation
Product Information http://www.westerndigital.com/en/products
[ LITE-ON LTR-52246S ]
Device Properties:
Driver Description LITE-ON LTR-52246S
INF File cdrom.inf
Optical Drive Properties:
Manufacturer Lite-On
Device Type CD-RW
Speed 52x/24x/52x
Company Name LITE-ON IT Corp.
Product Information http://www.liteon.com/prod/productIndex.do?xml_id=4
[ Primary IDE Channel ]
Device Properties:
Driver Description Primary IDE Channel
Driver Version 5.1.2600.1106
INF File mshdc.inf
Device Resources:
IRQ 14
Port 01F0-01F7
Port 03F6-03F6
[ Secondary IDE Channel ]
Device Properties:
Driver Description Secondary IDE Channel
INF File mshdc.inf
Device Resources:
IRQ 15
Port 0170-0177
Port 0376-0376
[ SiS 5513 IDE UDMA Controller ]
Device Properties:
Driver Description SiS 5513 IDE UDMA Controller
Driver Date 9/15/2003
Driver Version 5.1.1039.2041
Driver Provider Silicon Integrated Systems Corp.
INF File oem4.inf
Device Resources:
Port 4000-400F
--------[ Logical Drives ]----------------------------------------------------------------------------------------------
A: Removable Disk
C: Local Disk NTFS 84A2-8F49 49999 MB 39891 MB 80 %
D: Optical Drive
--------[ Physical Drives ]---------------------------------------------------------------------------------------------
[ Drive #1 (74.5 GB) ]
#1 (Active) NTFS C: 0 MB 49999 MB
--------[ Optical Drives ]----------------------------------------------------------------------------------------------
LITE-ON LTR-52246S Lite-On CD-RW 52x/24x/52x
--------[ ASPI ]--------------------------------------------------------------------------------------------------------
00 00 00 Disk Drive WDC WD80 0BB-00CAA1
00 07 00 Host Adapter atapi
01 01 00 Optical Drive LITE-ON LTR-52246S
01 07 00 Host Adapter atapi
--------[ ATA ]---------------------------------------------------------------------------------------------------------
[ WDC WD800BB-00CAA1 (WD-WMA8E8823325) ]
ATA Device Properties:
Model ID WDC WD800BB-00CAA1
Serial Number WD-WMA8E8823325
Revision 17.07W17
Parameters 155061 cylinders, 16 heads, 63 sectors per track, 600 bytes per sector
LBA Sectors 156301488
Buffer 2 MB (Dual Ported, Read Ahead)
Multiple Sectors 16
ECC Bytes 40
Max. PIO Transfer Mode PIO 4
Max. UDMA Transfer Mode UDMA 5 (ATA-100)
Active UDMA Transfer Mode UDMA 2 (ATA-33)
Unformatted Capacity 89436 MB
ATA Device Features:
SMART Supported
Security Mode Supported
Power Management Supported
Advanced Power Management Not Supported
Write Cache Supported
Host Protected Area Supported
Power-Up In Standby Not Supported
Automatic Acoustic Management Supported
48-bit LBA Not Supported
Device Configuration Overlay Supported
ATA Device Manufacturer:
--------[ SMART ]-------------------------------------------------------------------------------------------------------
01 Raw Read Error Rate 51 200 200 0 OK: Value is normal
03 Spin Up Time 21 109 96 3641 OK: Value is normal
04 Start/Stop Count 40 100 100 159 OK: Value is normal
05 Reallocated Sector Count 140 200 200 0 OK: Value is normal
07 Seek Error Rate 51 100 253 0 OK: Value is normal
09 Power-On Time Count 0 94 94 4395 OK: Always passing
0A Spin Retry Count 51 100 100 0 OK: Value is normal
0B Calibration Retry Count 51 100 100 0 OK: Value is normal
0C Power Cycle Count 0 100 100 152 OK: Always passing
C4 Reallocation Event Count 0 200 200 0 OK: Always passing
C5 Current Pending Sector Count 0 200 200 0 OK: Always passing
C6 Off-Line Uncorrectable Sector Count 0 200 200 0 OK: Always passing
C7 Ultra ATA CRC Error Rate 0 200 200 0 OK: Always passing
C8 Write Error Rate 51 200 200 0 OK: Value is normal
--------[ Windows Network ]---------------------------------------------------------------------------------------------
[ Realtek RTL8139 Family PCI Fast Ethernet NIC ]
Network Adapter Properties:
Network Adapter Realtek RTL8139 Family PCI Fast Ethernet NIC
Interface Type Ethernet
Hardware Address 00-50-8D-A3-20-0C
Connection Name Local Area Connection
Connection Speed 10 Mbps
MTU 1500 bytes
DHCP Lease Obtained 12/18/2004 9:07:29 PM
DHCP Lease Expires 12/18/2004 10:07:29 PM
Bytes Received 104013 (101.6 KB)
Bytes Sent 39236 (38.3 KB)
Network Adapter Manufacturer:
Company Name Realtek Semiconductor Corp.
Product Information http://www.realtek.com.tw/products/products1-1.aspx?lineid=1
Driver Download http://www.realtek.com.tw/downloads/downloads1-1.aspx?lineid=1
--------[ PCI / PnP Network ]-------------------------------------------------------------------------------------------
Realtek RTL8139 Fast Ethernet Adapter PCI
--------[ DirectX Video ]-----------------------------------------------------------------------------------------------
[ Primary Display Driver ]
DirectDraw Device Properties:
DirectDraw Driver Name display
DirectDraw Driver Description Primary Display Driver
Hardware Driver vga.dll
Hardware Description
--------[ DirectX Sound ]-----------------------------------------------------------------------------------------------
[ Primary Sound Driver ]
DirectSound Device Properties:
Device Description Primary Sound Driver
Driver Module
Primary Buffers 1
Min / Max Secondary Buffers Sample Rate 100 / 192000 Hz
Primary Buffers Sound Formats 8-bit, 16-bit, Mono, Stereo
Secondary Buffers Sound Formats 8-bit, 16-bit, Mono, Stereo
Total / Free Sound Buffers 33 / 32
Total / Free Static Sound Buffers 33 / 32
Total / Free Streaming Sound Buffers 33 / 32
Total / Free 3D Sound Buffers 33 / 32
Total / Free 3D Static Sound Buffers 33 / 32
Total / Free 3D Streaming Sound Buffers 33 / 32
DirectSound Device Features:
Certified Driver Yes
Emulated Device No
Precise Sample Rate Supported
[ Realtek AC97 Audio ]
Device Description Realtek AC97 Audio
Driver Module ALCXWDM.SYS
Primary Buffers 1
Emulated Device No
--------[ DirectX Music ]-----------------------------------------------------------------------------------------------
DirectMusic Device Properties:
Synthesizer Type Software
Device Class Output Port
Device Type WDM Multimedia
Audio Channels 2
MIDI Channels 16000
Voices 1000
Available Memory System Memory
DirectMusic Device Features:
Built-In GM Instrument Set No
Built-In Roland GS Sound Set No
DirectSound Not Supported
DLS L1 Sample Collections Supported
DLS L2 Sample Collections Not Supported
External MIDI Port No
Fixed DLS Memory Size No
Port Sharing Not Supported
Chorus Effect Not Supported
Delay Effect Not Supported
Reverb Effect Supported
[ Microsoft MIDI Mapper [Emulated] ]
Device Description Microsoft MIDI Mapper [Emulated]
Synthesizer Type Hardware
Device Type Windows Multimedia
MIDI Channels 16
DLS L1 Sample Collections Not Supported
Port Sharing Supported
Reverb Effect Not Supported
[ Microsoft GS Wavetable SW Synth [Emulated] ]
Device Description Microsoft GS Wavetable SW Synth [Emulated]
MIDI Channels 16
[ Microsoft Synthesizer ]
Device Description Microsoft Synthesizer
Device Type User-Mode Synthesizer
Audio Channels 2
MIDI Channels 16000
Voices 1000
DirectSound Supported
DLS L2 Sample Collections Supported
--------[ DirectX Input ]-----------------------------------------------------------------------------------------------
[ Mouse ]
DirectInput Device Properties:
Device Description Mouse
Device Type Mouse
Device Subtype Unknown
Axes 2
Buttons/Keys 3
DirectInput Device Features:
Emulated Device Yes
Alias Device No
Polled Device No
Polled Data Format No
Attack Force Feedback Not Supported
Deadband Force Feedback Not Supported
Fade Force Feedback Not Supported
Saturation Force Feedback Not Supported
+/- Force Feedback Coefficients Not Supported
+/- Force Feedback Saturation Not Supported
[ Keyboard ]
Device Description Keyboard
Device Type Keyboard
Device Subtype IBM PC Enhanced 101/102-key or Microsoft Natural keyboard
Buttons/Keys 128
Emulated Device Yes
Alias Device No
Polled Device No
--------[ Windows Devices ]---------------------------------------------------------------------------------------------
[ Devices ]
Computer:
ACPI Uniprocessor PC 5.1.2600.0
Disk drives:
WDC WD800BB-00CAA1 5.1.2535.0
Display adapters:
RADEON 9600 SERIES 6.14.10.6444
RADEON 9600 SERIES - Secondary 6.14.10.6444
DVD/CD-ROM drives:
LITE-ON LTR-52246S 5.1.2535.0
Floppy disk controllers:
Standard floppy disk controller 5.1.2600.0
Floppy disk drives:
Floppy disk drive 5.1.2600.0
IDE ATA/ATAPI controllers:
Primary IDE Channel 5.1.2600.1106
Secondary IDE Channel 5.1.2600.1106
SiS 5513 IDE UDMA Controller 5.1.1039.2041
Keyboards:
Easy Internet Keyboard 2.15.0.0
Mice and other pointing devices:
Logitech-compatible Mouse PS/2 9.75.0.0
Network adapters:
Direct Parallel 5.1.2535.0
Realtek RTL8139 Family PCI Fast Ethernet NIC 5.396.530.2001
Realtek RTL8139 Family PCI Fast Ethernet NIC - Packet Scheduler Miniport5.1.2535.0
WAN Miniport (IP) 5.1.2535.0
WAN Miniport (IP) - Packet Scheduler Miniport 5.1.2535.0
WAN Miniport (L2TP) 5.1.2535.0
WAN Miniport (PPPOE) 5.1.2535.0
WAN Miniport (PPTP) 5.1.2535.0
Non-Plug and Play Drivers:
AC2003
AFD Networking Support Environment
AVG Network Redirector
AVG7 Kernel
AVG7 Rezident Driver
AVG7 Wrap Driver
Beep
dmboot
dmload
Fips
Generic Packet Classifier
HTTP
IP Network Address Translator
IPSEC driver
ksecdd
mnmdd
mountmgr
NDIS System Driver
NDIS Usermode I/O Protocol
NDProxy
NetBios over Tcpip
Null
PartMgr
ParVdm
PCIIde
RDPCDD
Remote Access Auto Connection Driver
Remote Access IP ARP Driver
Remote Access NDIS TAPI Driver
TCP/IP Protocol Driver
VgaSave
VolSnap
Ports (COM & LPT):
Communications Port (COM1) 5.1.2600.0
Communications Port (COM2) 5.1.2600.0
ECP Printer Port (LPT1) 5.1.2600.0
Processors:
Intel(R) Pentium(R) 4 CPU 2.66GHz 5.1.2600.0
Sound, video and game controllers:
Audio Codecs 5.1.2535.0
Legacy Audio Drivers 5.1.2535.0
Legacy Video Capture Devices 5.1.2535.0
Media Control Devices 5.1.2535.0
Microsoft Kernel System Audio Device 5.1.2535.0
Microsoft Kernel Wave Audio Mixer 5.1.2535.0
Microsoft WINMM WDM Audio Compatibility Driver 5.1.2535.0
Realtek AC'97 Audio 5.10.0.5630
Video Codecs 5.1.2535.0
Storage volumes:
Generic volume 5.1.2600.0
System devices:
ACPI Fan 5.1.2600.0
ACPI Fixed Feature Button 5.1.2600.0
ACPI Power Button 5.1.2600.0
ACPI Sleep Button 5.1.2600.0
ACPI Thermal Zone 5.1.2600.0
Direct memory access controller 5.1.2600.0
ISAPNP Read Data Port 5.1.2600.0
Logical Disk Manager 5.1.2600.0
Microcode Update Device 5.1.2600.0
Microsoft ACPI-Compliant System 5.1.2535.0
Microsoft System Management BIOS Driver 5.1.2600.2180
Motherboard resources 5.1.2600.0
Numeric data processor 5.1.2600.0
PCI bus 5.1.2600.0
PCI standard host CPU bridge 5.1.2600.0
PCI standard ISA bridge 5.1.2600.0
Plug and Play Software Device Enumerator 5.1.2600.0
Printer Port Logical Interface 5.1.2600.0
Programmable interrupt controller 5.1.2600.0
SiS Accelerated Graphics Port 7.2.0.1170
System board 5.1.2600.0
System CMOS/real time clock 5.1.2600.0
System speaker 5.1.2600.0
System timer 5.1.2600.0
Terminal Server Device Redirector 5.1.2600.0
Terminal Server Keyboard Driver 5.1.2600.0
Terminal Server Mouse Driver 5.1.2600.0
Volume Manager 5.1.2600.0
Universal Serial Bus controllers:
SiS 7001 PCI to USB Open Host Controller 5.1.2600.1106
SiS PCI to USB Enhanced Host Controller 5.1.2600.0
USB Root Hub 5.1.2600.1106
[ Computer / ACPI Uniprocessor PC ]
Device Properties:
Driver Description ACPI Uniprocessor PC
INF File hal.inf
[ Disk drives / WDC WD800BB-00CAA1 ]
Device Properties:
INF File disk.inf
[ Display adapters / RADEON 9600 SERIES ]
Device Properties:
Driver Description RADEON 9600 SERIES
Driver Date 4/21/2004
Driver Version 6.14.10.6444
Driver Provider ATI Technologies Inc.
INF File oem1.inf
Device Resources:
IRQ 16
Memory 000A0000-000BFFFF
Memory C0000000-CFFFFFFF
Memory E9000000-E900FFFF
Port 03B0-03BB
Port 03C0-03DF
Port D000-D0FF
[ Display adapters / RADEON 9600 SERIES - Secondary ]
Device Properties:
Driver Description RADEON 9600 SERIES - Secondary
INF File oem1.inf
Device Resources:
Memory D0000000-DFFFFFFF
Memory E9FF0000-E9FFFFFF
[ DVD/CD-ROM drives / LITE-ON LTR-52246S ]
Device Properties:
INF File cdrom.inf
[ Floppy disk controllers / Standard floppy disk controller ]
Device Properties:
Driver Description Standard floppy disk controller
INF File fdc.inf
Device Resources:
DMA 02
IRQ 06
Port 03F0-03F5
Port 03F7-03F7
[ Floppy disk drives / Floppy disk drive ]
Device Properties:
[ IDE ATA/ATAPI controllers / Primary IDE Channel ]
Device Properties:
INF File mshdc.inf
Device Resources:
IRQ 14
Port 01F0-01F7
Port 03F6-03F6
[ IDE ATA/ATAPI controllers / Secondary IDE Channel ]
Device Properties:
INF File mshdc.inf
Device Resources:
IRQ 15
Port 0170-0177
Port 0376-0376
[ IDE ATA/ATAPI controllers / SiS 5513 IDE UDMA Controller ]
Device Properties:
INF File oem4.inf
Device Resources:
Port 4000-400F
Device Resources:
IRQ 01
Port 0060-0060
Port 0064-0064
[ Network adapters / Direct Parallel ]
Device Properties:
Driver Description Direct Parallel
INF File netrasa.inf
[ Network adapters / Realtek RTL8139 Family PCI Fast Ethernet NIC ]
Device Properties:
Driver Description Realtek RTL8139 Family PCI Fast Ethernet NIC
Driver Version 5.396.530.2001
INF File netrtsnt.inf
Device Resources:
IRQ 18
Memory EA004000-EA0040FF
Port E800-E8FF
[ Network adapters / Realtek RTL8139 Family PCI Fast Ethernet NIC - Packet Scheduler Miniport ]
Device Properties:
Driver Description Realtek RTL8139 Family PCI Fast Ethernet NIC - Packet Scheduler Miniport
INF File netpsa.inf
[ Network adapters / WAN Miniport (IP) ]
Device Properties:
Driver Description WAN Miniport (IP)
[ Network adapters / WAN Miniport (IP) - Packet Scheduler Miniport ]
Device Properties:
Driver Description WAN Miniport (IP) - Packet Scheduler Miniport
INF File netpsa.inf
[ Network adapters / WAN Miniport (L2TP) ]
Device Properties:
Driver Description WAN Miniport (L2TP)
[ Network adapters / WAN Miniport (PPPOE) ]
Device Properties:
Driver Description WAN Miniport (PPPOE)
[ Network adapters / WAN Miniport (PPTP) ]
Device Properties:
Driver Description WAN Miniport (PPTP)
[ Ports (COM & LPT) / Communications Port (COM1) ]
Device Properties:
Driver Description Communications Port (COM1)
INF File msports.inf
Device Resources:
IRQ 04
Port 03F8-03FF
[ Ports (COM & LPT) / Communications Port (COM2) ]
Device Properties:
Driver Description Communications Port (COM2)
Device Resources:
IRQ 03
Port 02F8-02FF
[ Ports (COM & LPT) / ECP Printer Port (LPT1) ]
Device Properties:
Driver Description ECP Printer Port (LPT1)
Device Resources:
DMA 03
Port 0378-037F
Port 0778-077B
[ Processors / Intel(R) Pentium(R) 4 CPU 2.66GHz ]
Device Properties:
Driver Description Intel(R) Pentium(R) 4 CPU 2.66GHz
Driver Date 4/1/2004
INF File cpu.inf
[ Sound, video and game controllers / Audio Codecs ]
Device Properties:
Driver Description Audio Codecs
INF File wave.inf
[ Sound, video and game controllers / Legacy Audio Drivers ]
Device Properties:
Driver Description Legacy Audio Drivers
INF File wave.inf
[ Sound, video and game controllers / Legacy Video Capture Devices ]
Device Properties:
Driver Description Legacy Video Capture Devices
INF File wave.inf
[ Sound, video and game controllers / Media Control Devices ]
Device Properties:
Driver Description Media Control Devices
INF File wave.inf
[ Sound, video and game controllers / Microsoft Kernel System Audio Device ]
Device Properties:
Driver Description Microsoft Kernel System Audio Device
INF File wdmaudio.inf
[ Sound, video and game controllers / Microsoft Kernel Wave Audio Mixer ]
Device Properties:
Driver Description Microsoft Kernel Wave Audio Mixer
[ Sound, video and game controllers / Microsoft WINMM WDM Audio Compatibility Driver ]
Device Properties:
Driver Description Microsoft WINMM WDM Audio Compatibility Driver
[ Sound, video and game controllers / Realtek AC’97 Audio ]
Device Properties:
Driver Description Realtek AC'97 Audio
Driver Date 7/1/2004
Driver Version 5.10.0.5630
Driver Provider Realtek Semiconductor Corp.
INF File oem2.inf
Device Resources:
IRQ 18
Port E000-E0FF
Port E400-E47F
[ Sound, video and game controllers / Video Codecs ]
Device Properties:
Driver Description Video Codecs
INF File wave.inf
[ Storage volumes / Generic volume ]
Device Properties:
Driver Description Generic volume
INF File volume.inf
[ System devices / ACPI Fan ]
Device Properties:
Driver Description ACPI Fan
INF File machine.inf
[ System devices / ACPI Fixed Feature Button ]
Device Properties:
Driver Description ACPI Fixed Feature Button
[ System devices / ACPI Power Button ]
Device Properties:
Driver Description ACPI Power Button
[ System devices / ACPI Sleep Button ]
Device Properties:
Driver Description ACPI Sleep Button
[ System devices / ACPI Thermal Zone ]
Device Properties:
Driver Description ACPI Thermal Zone
[ System devices / Direct memory access controller ]
Device Properties:
Driver Description Direct memory access controller
Device Resources:
DMA 04
Port 0000-000F
Port 0080-0090
Port 0094-009F
Port 00C0-00DF
[ System devices / ISAPNP Read Data Port ]
Device Properties:
Driver Description ISAPNP Read Data Port
Device Resources:
Port 0274-0277
Port 0279-0279
Port 0A79-0A79
[ System devices / Logical Disk Manager ]
Device Properties:
Driver Description Logical Disk Manager
[ System devices / Microcode Update Device ]
Device Properties:
Driver Description Microcode Update Device
[ System devices / Microsoft ACPI-Compliant System ]
Device Properties:
Driver Description Microsoft ACPI-Compliant System
INF File acpi.inf
Device Resources:
IRQ 09
[ System devices / Microsoft System Management BIOS Driver ]
Device Properties:
Driver Description Microsoft System Management BIOS Driver
Driver Version 5.1.2600.2180
[ System devices / Motherboard resources ]
Device Properties:
Driver Description Motherboard resources
[ System devices / Numeric data processor ]
Device Properties:
Driver Description Numeric data processor
Device Resources:
IRQ 13
Port 00F0-00FF
[ System devices / PCI bus ]
Device Properties:
Driver Description PCI bus
Device Resources:
Memory 40000000-FEBFFFFF
Port 0000-047F
Port 0490-0CF7
Port 0D00-0FFF
Port 1100-FFFF
[ System devices / PCI standard host CPU bridge ]
Device Properties:
Driver Description PCI standard host CPU bridge
[ System devices / PCI standard ISA bridge ]
Device Properties:
Driver Description PCI standard ISA bridge
[ System devices / Plug and Play Software Device Enumerator ]
Device Properties:
Driver Description Plug and Play Software Device Enumerator
[ System devices / Printer Port Logical Interface ]
Device Properties:
Driver Description Printer Port Logical Interface
[ System devices / Programmable interrupt controller ]
Device Properties:
Driver Description Programmable interrupt controller
Device Resources:
Port 0020-0021
Port 00A0-00A1
[ System devices / SiS Accelerated Graphics Port ]
Device Properties:
Driver Description SiS Accelerated Graphics Port
Driver Date 7/18/2003
Driver Version 7.2.0.1170
Driver Provider SiS
INF File oem3.inf
Device Resources:
Memory C0000000-DFFFFFFF
Memory E0000000-E7FFFFFF
Memory E8000000-E9FFFFFF
Port 03B0-03BB
Port 03C0-03DF
Port D000-DFFF
[ System devices / System board ]
Device Properties:
Driver Description System board
Device Resources:
Memory 00000000-0009FFFF
Memory 000CD000-000CFFFF
Memory 000F0000-000F7FFF
Memory 000F8000-000FBFFF
Memory 000FC000-000FFFFF
Memory 00100000-3FFEFFFF
Memory 3FFF0000-3FFFFFFF
Memory FEC00000-FECFFFFF
Memory FEE00000-FEEFFFFF
Memory FFEE0000-FFEFFFFF
Memory FFFE0000-FFFEFFFF
Memory FFFF0000-FFFFFFFF
[ System devices / System CMOS/real time clock ]
Device Properties:
Driver Description System CMOS/real time clock
Device Resources:
IRQ 08
Port 0070-0073
[ System devices / System speaker ]
Device Properties:
Driver Description System speaker
Device Resources:
Port 0061-0061
[ System devices / System timer ]
Device Properties:
Driver Description System timer
Device Resources:
IRQ 00
Port 0040-0043
[ System devices / Terminal Server Device Redirector ]
Device Properties:
Driver Description Terminal Server Device Redirector
[ System devices / Terminal Server Keyboard Driver ]
Device Properties:
Driver Description Terminal Server Keyboard Driver
[ System devices / Terminal Server Mouse Driver ]
Device Properties:
Driver Description Terminal Server Mouse Driver
[ System devices / Volume Manager ]
Device Properties:
Driver Description Volume Manager
[ Universal Serial Bus controllers / SiS 7001 PCI to USB Open Host Controller ]
Device Properties:
Driver Description SiS 7001 PCI to USB Open Host Controller
INF File usbport.inf
Device Resources:
IRQ 21
Memory EA001000-EA001FFF
Device Properties:
Device Resources:
IRQ 20
Memory EA000000-EA000FFF
Device Properties:
Device Resources:
IRQ 22
Memory EA002000-EA002FFF
[ Universal Serial Bus controllers / SiS PCI to USB Enhanced Host Controller ]
Device Properties:
Driver Description SiS PCI to USB Enhanced Host Controller
Driver Date 6/1/2002
Device Resources:
IRQ 23
Memory EA003000-EA003FFF
[ Universal Serial Bus controllers / USB Root Hub ]
Device Properties:
Driver Description USB Root Hub
Device Properties:
Device Properties:
Device Properties:
--------[ Physical Devices ]--------------------------------------------------------------------------------------------
PCI Devices:
Bus 1, Device 0, Function 1 ATI Radeon 9600 (RV350) - Secondary Video Adapter
Bus 1, Device 0, Function 0 ATI Radeon 9600 (RV350) Video Adapter
Bus 0, Device 14, Function 0 Realtek RTL8139 Fast Ethernet Adapter
Bus 0, Device 0, Function 0 SiS 661FX Chipset - Host-PCI Bridge
Bus 0, Device 3, Function 0 SiS 7001 PCI-USB Open Host Controller
Bus 0, Device 3, Function 1 SiS 7001 PCI-USB Open Host Controller
Bus 0, Device 3, Function 2 SiS 7001 PCI-USB Open Host Controller
Bus 0, Device 3, Function 3 SiS 7002 USB 2.0 Enhanced Host Controller
Bus 0, Device 2, Function 7 SiS 7012 Audio Device
Bus 0, Device 2, Function 5 SiS 85C513 IDE Controller
Bus 0, Device 2, Function 0 SiS 964 PCI-ISA Bridge
Bus 0, Device 1, Function 0 SiS AGP Controller
PnP Devices:
PNP0303 101/102-Key or MS Natural Keyboard
PNP0501 16550A-compatible UART Serial Port
PNP0C08 ACPI Driver/BIOS
FIXEDBUTTON ACPI Fixed Feature Button
THERMALZONE ACPI Thermal Zone
PNP0200 DMA Controller
PNP0401 ECP Parallel Port
PNP0C0B Fan
PNP0700 Floppy Disk Controller
GENUINEINTEL_-_X86_FAMILY_15_MODEL_2 Intel(R) Pentium(R) 4 CPU 2.66GHz
PNP0F13 Logitech PS/2 Port Mouse
PNP0C02 Motherboard Resources
PNP0C04 Numeric Data Processor
PNP0800 PC Speaker
PNP0A03 PCI Bus
PNP0C0C Power Button
PNP0000 Programmable Interrupt Controller
PNP0B00 Real-Time Clock
PNP0C0E Sleep Button
PNP0C01 System Board Extension
PNP0100 System Timer
LPT PnP Devices:
MICROSOFTRAWPORT Printer Port Logical Interface
Ports:
COM1 Communications Port (COM1)
COM2 Communications Port (COM2)
LPT1 ECP Printer Port (LPT1)
--------[ Device Resources ]--------------------------------------------------------------------------------------------
DMA 02 Exclusive Standard floppy disk controller
DMA 03 Exclusive ECP Printer Port (LPT1)
DMA 04 Exclusive Direct memory access controller
IRQ 00 Exclusive System timer
IRQ 01 Exclusive Easy Internet Keyboard
IRQ 03 Exclusive Communications Port (COM2)
IRQ 04 Exclusive Communications Port (COM1)
IRQ 06 Exclusive Standard floppy disk controller
IRQ 08 Exclusive System CMOS/real time clock
IRQ 09 Shared Microsoft ACPI-Compliant System
IRQ 12 Exclusive Logitech-compatible Mouse PS/2
IRQ 13 Exclusive Numeric data processor
IRQ 14 Exclusive Primary IDE Channel
IRQ 15 Exclusive Secondary IDE Channel
IRQ 16 Shared RADEON 9600 SERIES
IRQ 18 Shared Realtek RTL8139 Family PCI Fast Ethernet NIC
IRQ 18 Shared Realtek AC'97 Audio
IRQ 20 Shared SiS 7001 PCI to USB Open Host Controller
IRQ 21 Shared SiS 7001 PCI to USB Open Host Controller
IRQ 22 Shared SiS 7001 PCI to USB Open Host Controller
IRQ 23 Shared SiS PCI to USB Enhanced Host Controller
Memory 00000000-0009FFFF Exclusive System board
Memory 000A0000-000BFFFF Shared PCI bus
Memory 000A0000-000BFFFF Shared RADEON 9600 SERIES
Memory 000A0000-000BFFFF Undetermined SiS Accelerated Graphics Port
Memory 000CD000-000CFFFF Exclusive System board
Memory 000F0000-000F7FFF Exclusive System board
Memory 000F8000-000FBFFF Exclusive System board
Memory 000FC000-000FFFFF Exclusive System board
Memory 00100000-3FFEFFFF Exclusive System board
Memory 3FFF0000-3FFFFFFF Exclusive System board
Memory 40000000-FEBFFFFF Shared PCI bus
Memory C0000000-CFFFFFFF Exclusive RADEON 9600 SERIES
Memory C0000000-DFFFFFFF Exclusive SiS Accelerated Graphics Port
Memory D0000000-DFFFFFFF Exclusive RADEON 9600 SERIES - Secondary
Memory E0000000-E7FFFFFF Exclusive SiS Accelerated Graphics Port
Memory E8000000-E9FFFFFF Exclusive SiS Accelerated Graphics Port
Memory E9000000-E900FFFF Exclusive RADEON 9600 SERIES
Memory E9FF0000-E9FFFFFF Exclusive RADEON 9600 SERIES - Secondary
Memory EA000000-EA000FFF Exclusive SiS 7001 PCI to USB Open Host Controller
Memory EA001000-EA001FFF Exclusive SiS 7001 PCI to USB Open Host Controller
Memory EA002000-EA002FFF Exclusive SiS 7001 PCI to USB Open Host Controller
Memory EA003000-EA003FFF Exclusive SiS PCI to USB Enhanced Host Controller
Memory EA004000-EA0040FF Exclusive Realtek RTL8139 Family PCI Fast Ethernet NIC
Memory FEC00000-FECFFFFF Exclusive System board
Memory FEE00000-FEEFFFFF Exclusive System board
Memory FFEE0000-FFEFFFFF Exclusive System board
Memory FFFE0000-FFFEFFFF Exclusive System board
Memory FFFF0000-FFFFFFFF Exclusive System board
Port 0000-000F Exclusive Direct memory access controller
Port 0000-047F Shared PCI bus
Port 0010-001F Exclusive Motherboard resources
Port 0020-0021 Exclusive Programmable interrupt controller
Port 0022-003F Exclusive Motherboard resources
Port 0040-0043 Exclusive System timer
Port 0044-005F Exclusive Motherboard resources
Port 0060-0060 Exclusive Easy Internet Keyboard
Port 0061-0061 Exclusive System speaker
Port 0062-0063 Exclusive Motherboard resources
Port 0064-0064 Exclusive Easy Internet Keyboard
Port 0065-006F Exclusive Motherboard resources
Port 0070-0073 Exclusive System CMOS/real time clock
Port 0074-007F Exclusive Motherboard resources
Port 0080-0090 Exclusive Direct memory access controller
Port 0091-0093 Exclusive Motherboard resources
Port 0094-009F Exclusive Direct memory access controller
Port 00A0-00A1 Exclusive Programmable interrupt controller
Port 00A2-00BF Exclusive Motherboard resources
Port 00C0-00DF Exclusive Direct memory access controller
Port 00E0-00EF Exclusive Motherboard resources
Port 00F0-00FF Exclusive Numeric data processor
Port 0170-0177 Exclusive Secondary IDE Channel
Port 01F0-01F7 Exclusive Primary IDE Channel
Port 0274-0277 Exclusive ISAPNP Read Data Port
Port 0279-0279 Exclusive ISAPNP Read Data Port
Port 0290-0297 Exclusive Motherboard resources
Port 02F8-02FF Exclusive Communications Port (COM2)
Port 0376-0376 Exclusive Secondary IDE Channel
Port 0378-037F Exclusive ECP Printer Port (LPT1)
Port 03B0-03BB Shared RADEON 9600 SERIES
Port 03B0-03BB Undetermined SiS Accelerated Graphics Port
Port 03C0-03DF Shared RADEON 9600 SERIES
Port 03C0-03DF Undetermined SiS Accelerated Graphics Port
Port 03F0-03F5 Exclusive Standard floppy disk controller
Port 03F6-03F6 Exclusive Primary IDE Channel
Port 03F7-03F7 Exclusive Standard floppy disk controller
Port 03F8-03FF Exclusive Communications Port (COM1)
Port 0490-0CF7 Shared PCI bus
Port 04D0-04D1 Exclusive Motherboard resources
Port 0778-077B Exclusive ECP Printer Port (LPT1)
Port 0800-0805 Exclusive Motherboard resources
Port 0A79-0A79 Exclusive ISAPNP Read Data Port
Port 0D00-0FFF Shared PCI bus
Port 1100-FFFF Shared PCI bus
Port 4000-400F Exclusive SiS 5513 IDE UDMA Controller
Port D000-D0FF Exclusive RADEON 9600 SERIES
Port D000-DFFF Exclusive SiS Accelerated Graphics Port
Port E000-E0FF Exclusive Realtek AC'97 Audio
Port E400-E47F Exclusive Realtek AC'97 Audio
Port E800-E8FF Exclusive Realtek RTL8139 Family PCI Fast Ethernet NIC
--------[ Power Management ]--------------------------------------------------------------------------------------------
Power Management Properties:
Current Power Source AC Line
Battery Status No Battery
Full Battery Lifetime Unknown
Remaining Battery Lifetime Unknown
--------[ Debug - PCI ]-------------------------------------------------------------------------------------------------
B00 D00 F00: SiS 661FX Chipset - Host-PCI Bridge
Offset 00: 39 10 61 06 07 00 10 22 11 00 00 06 00 20 80 00
Offset 10: 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 7B 14 06 18
Offset 30: 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00
Offset 40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 50: FF 09 01 83 43 03 0D 0D 03 25 08 00 12 DB 20 06
Offset 60: 6B 6B 6C 00 03 80 DA 82 01 10 E0 00 6A 00 80 00
Offset 70: 0F 9F 00 80 02 00 00 90 00 00 00 00 02 0F 00 44
Offset 80: 22 27 30 03 81 00 04 2B 00 00 00 01 00 00 00 40
Offset 90: 00 00 00 00 50 00 00 00 B0 80 2C 02 00 00 00 1B
Offset A0: A5 A8 77 42 03 03 01 33 41 AA 40 00 44 01 00 04
Offset B0: 00 00 00 80 81 01 20 00 12 3C 30 30 00 00 30 00
Offset C0: 02 00 35 00 0B 4E 00 1F 02 03 00 00 00 00 00 00
Offset D0: E0 01 00 00 20 0F 01 00 00 00 10 00 00 00 00 88
Offset E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset F0: 18 15 00 00 00 00 AA AA 00 00 00 00 00 00 00 00
B00 D01 F00: SiS AGP Controller
Offset 00: 39 10 03 00 07 01 20 00 00 00 04 06 00 40 01 00
Offset 10: 00 00 00 00 00 00 00 00 00 01 01 20 D0 D0 20 20
Offset 20: 00 E8 F0 E9 00 C0 F0 DF 00 00 00 00 00 00 00 00
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0E 00
Offset 50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset D0: 22 42 30 06 09 FF FF 01 60 60 AA 12 03 07 07 23
Offset E0: 23 47 15 A0 00 00 00 00 55 00 55 E5 00 00 00 00
Offset F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B00 D02 F00: SiS 964 PCI-ISA Bridge
Offset 00: 39 10 64 09 0F 00 00 02 36 00 01 06 00 00 80 00
Offset 10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 40: 92 8A 80 8B 80 40 3D DD 10 00 00 00 11 30 04 01
Offset 50: 11 38 02 01 20 0B 20 00 FF FF 12 00 00 05 00 00
Offset 60: 8A 8B 89 85 FF C1 0C 12 09 80 00 46 B7 00 02 14
Offset 70: 00 00 FF FF 00 10 03 2C 20 00 20 80 16 00 00 00
Offset 90: 1F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C0: 01 00 00 40 00 00 00 00 0F 9F 00 00 00 00 00 41
Offset D0: 20 0D 00 01 22 26 30 00 81 00 04 2B AA AA AA AA
Offset E0: 40 00 00 D8 7C 00 44 00 00 00 00 00 00 00 00 00
Offset F0: 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B00 D02 F05: SiS 85C513 IDE Controller
Offset 00: 39 10 13 55 05 00 10 02 01 8A 01 01 00 80 00 00
Offset 10: F1 01 00 00 F5 03 00 00 71 01 00 00 75 03 00 00
Offset 20: 01 40 00 00 00 00 00 00 00 00 00 00 7B 14 06 18
Offset 30: 00 00 00 00 58 00 00 00 00 00 00 00 00 01 00 00
Offset 40: 00 00 00 00 00 00 00 00 10 00 06 00 00 00 00 00
Offset 50: 9B A1 9A 21 2A 96 C5 D0 01 00 02 80 00 00 00 00
Offset 60: FB AA FB AA 00 00 00 00 81 00 00 81 00 00 00 00
Offset 70: 56 23 06 04 00 60 1C 1E 00 60 1C 1E 56 23 06 04
Offset D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B00 D02 F07: SiS 7012 Audio Device
Offset 00: 39 10 12 70 05 00 90 02 A0 00 01 04 00 20 00 00
Offset 10: 01 E0 00 00 01 E4 00 00 00 00 00 00 00 00 00 00
Offset 30: 00 00 00 00 48 00 00 00 00 00 00 00 12 03 34 0B
Offset 40: 04 00 00 00 00 00 00 00 01 00 42 C6 00 00 00 00
Offset F0: 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B00 D03 F00: SiS 7001 PCI-USB Open Host Controller
Offset 00: 39 10 01 70 07 00 80 02 0F 10 03 0C 08 20 80 00
Offset 10: 00 00 00 EA 00 00 00 00 00 00 00 00 00 00 00 00
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 14 01 00 50
Offset 40: 00 00 00 00 5C AC 01 00 3F 02 00 00 00 00 00 00
Offset D0: 00 00 00 00 00 00 00 00 00 00 00 00 01 00 C2 C9
B00 D03 F01: SiS 7001 PCI-USB Open Host Controller
Offset 00: 39 10 01 70 07 00 80 02 0F 10 03 0C 08 20 00 00
Offset 10: 00 10 00 EA 00 00 00 00 00 00 00 00 00 00 00 00
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 15 02 00 50
B00 D03 F02: SiS 7001 PCI-USB Open Host Controller
Offset 10: 00 20 00 EA 00 00 00 00 00 00 00 00 00 00 00 00
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 16 03 00 50
Offset 40: 00 00 00 00 5C AC 01 00 7F 02 00 00 00 00 00 00
B00 D03 F03: SiS 7002 USB 2.0 Enhanced Host Controller
Offset 00: 39 10 02 70 06 00 90 02 00 20 03 0C 08 20 00 00
Offset 10: 00 30 00 EA 00 00 00 00 00 00 00 00 00 00 00 00
Offset 30: 00 00 00 00 50 00 00 00 00 00 00 00 17 04 00 50
Offset 40: 00 00 00 08 00 00 00 00 00 00 00 00 00 00 00 00
Offset 50: 01 00 C2 C9 00 00 00 00 0A 00 00 21 00 00 00 00
Offset 60: 20 20 FF 01 00 00 00 00 00 00 00 00 00 00 00 00
Offset 70: 01 00 00 00 00 00 00 C0 00 00 E7 3F 00 00 00 00
B00 D0E F00: Realtek RTL8139 Fast Ethernet Adapter
Offset 00: EC 10 39 81 05 00 90 02 10 00 00 02 00 20 00 00
Offset 10: 01 E8 00 00 00 40 00 EA 00 00 00 00 00 00 00 00
Offset 30: 00 00 00 00 50 00 00 00 00 00 00 00 12 01 20 40
Offset 50: 01 00 C2 F7 00 01 00 00 00 00 00 00 00 00 00 00
B01 D00 F00: ATI Radeon 9600 (RV350) Video Adapter
Offset 00: 02 10 50 41 07 00 B0 02 00 00 00 03 08 20 80 00
Offset 10: 08 00 00 C0 01 D0 00 00 00 00 00 E9 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 02 10 50 41
Offset 30: 00 00 00 00 58 00 00 00 00 00 00 00 10 01 08 00
Offset 40: 00 00 00 00 00 00 00 00 00 00 00 00 02 10 50 41
Offset 50: 01 00 02 06 00 00 00 00 02 50 30 00 1B 02 00 FF
Offset 60: 02 43 00 1F 00 00 00 00 00 00 00 00 00 00 00 00
Offset 80: 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B01 D00 F01: ATI Radeon 9600 (RV350) - Secondary Video Adapter
Offset 00: 02 10 70 41 07 00 B0 02 00 00 80 03 08 20 00 00
Offset 10: 08 00 00 D0 00 00 FF E9 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 02 10 51 41
Offset 30: 00 00 00 00 50 00 00 00 00 00 00 00 FF 00 08 00
Offset 60: 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00
--------[ Debug - Video BIOS ]------------------------------------------------------------------------------------------
C000:0000 U.h...........................IBM=.............. 761295520......
C000:0040 ??......$.......2004/01/15 11:26.....T..........DR(7....PA......
C000:0080 .. RADEON 9600LE SAMSUNG-E 400/203 PAL BIOS...(C) 1988-2003, ATI
C000:00C0 Technologies Inc. BK-ATI VER008.015.058.000. pa400203.815 v611
C000:0100 .V350AGP DGD1UN..OEM VER.000.000..l.......l....Z................
C000:0140 ..PAPA.........x.n..^.'.S.A...$TVS3................K...........
C000:0180 ................PCIR..PA........h.......ATI RADEON 9600 PRO.....
C000:01C0 ................................................................
C000:0200 ............q.......Wxx.........................................
C000:0240 ................................................................
C000:0280 ................................................0 ..3Q0`........
C000:02C0 ..OD..P ....P`........X ..........| ..........X`........hA.....
C000:0300 [email protected].....=..x.0 ..|...................
C000:0340 ........................ ...........+.......f..........`........
C000:0380 ..X:..........X:....!.....I............U...........U....&.......
C000:03C0 ..../.....m.....%......."".......M.......[..u..`...............@
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
