The rest of your specs would be nice so we can look for a new motherboard for you if you like? As for playing Halflife 2 perfectly do you mean perfectly on max settings or perfectly on modest settings? Do you have a maximum budget? Like $200 for the graphic card maybe? Thanks:)
[QUOTE=Exfoliate]
i got £75 to spend…my spec is amd athlon xp 2600+, 2.07ghz, 192mb ram(upgrading soon, adding 512mb)..
or the 38 euro card posted in the bargain zone, the 9700 pro, id agree with ex though too for around 150$ or 120-30 euro a 6600GT is much bang for the buck, and its deadly at overclocking too
[QUOTE=Addis]
Your motherboard is the MSI KM4M-L which has an AGP 8x slot.
For £75 you can get this Radeon 9600 XT. Its a good card for your money.
does this mean i don’t need to replace my motherboard if i want to upgrade my graphics card…
will this play games like half life 2 well?
[QUOTE=zRoCkIsAdDiCtInG]
It should paly reasonably well with settingson medium, you can always lower certain settings which don’t make much difference to the graphics to help performance if needed. But at £38, its a bargain.
You can go with the 6600GT, its £83 but it’ll be much ebtter than any of the original Radeon 9x cards.
