virus problem in XP
Hai
my computer is effected with a virus. I know it’s in startup but i can’t edit my “msconfig” or even i can’t edit regiestry by 'regedit". When i use this run command it is closes automatically. It’s something W32…@mm or like this ..
I don’t have any anti virus program in my computer right now. I tried to install Norton but when i try to open the file from cd the windows automatically close. …
Help me guys…
:confused:
Try installing this utility Free avast! 4 Home Edition - Free antivirus software - free virus protection for home PC I use it and find it to be very good.
as DavidNW says Avast is :swear:ing good, when i was using XP, i used it, another free antivirus is AVG but IMO avast is much better
W32.Rantokbro.U@mm it the name of the virus…what to do next … i can’t install any antivirus program in my computer … not even avast… .. help ma !!!
You could try the following link for information on the virus and how to go about removing it.
W32.Rontokbro.K@mm - Symantec.com
How long have you had it? Try system restore and restore to an earlier date.
If that doesn’t work, did your computer come with a recovery disk?
You might have a SMART Virus,There are allot of them going Around now days.
I just got rid of one last week on one of my other computers..They are very
hard to get rid of..
