First of all, the HDD is working all the time and slowing the system down… then I get the blue screen of death (no idea why), and the firewall is off and I can’t get it on and to make matters worse, there are all the time error messages saying failed this, broken that etc…
Believe me since I had to buy a Windows I got Vista but if I had xp I’d have installed it without a doubt…
Now my question is: do you know any maintenance tools (i.e. registry cleaner) for Vista? Also, does anyone know the cause of the constant HDD activity?
thanks a lot! yeah believe me, if I didn’t have to, I wouldn’t even use windows… I got Vista because I thought it’s stupid to get XP when a newer OS is there…
Tell me another thing please: Will there be any problem with installing XP PRO SP2 on 2 machines?
If you have 2 licences for it, or a multi-user licence then no. Otherwise you may encounter problems with Windows Activation, unless it’s a corporate edition which doesn’t need activating.
