vista ultimate boot problem
got a copy with my new laptop and decided to put it on my home pc. anyway installed fine i think but when i came to start up after the desktop installed its components restarted and skiped the boot screen and said the following.
booting ‘windows vista’
acpi
vista loader 2.1.2
done!
fallback 1
find–set-root /bootmgr
error 17: file not found
booting ‘windows nt/2000/xp’
fallback 2
find --set-root /ntldr
booting ‘enter command line’
boot failed! press any key to entre command line.
can anyone help oh yeah i did a full clean install of xp first the upgraded to vista but also have half a xp install on my second hdd would this have anything todo with it.
is it a real vista cd or just a recovery cd that came with the laptop?
real one its fine now got it working it was cos i had 2 xp on 2 different drives .
keep on getting a mini dump blue screen every 20 mins or so now and it restarts . anyone no why
Is this disk a full install disk or an upgrade disk? (2 xp on 2 different drives )
If this is the case, Then it is not a fresh install..
no that was the first problem id put 2 xps on the tried to upgrade to vista on one of them and it threw a wobbler but its ok now.
