vivo help
i have plugged my ps2 into my graphics card via vivo, i used an application called videoimpression 1.6 and when i click for it to capture through ATI Rage Theater, its all flashing screen, and i can just see the image, and there is a green line at the top, so this application must not be good enough to capture through the graphics card, is there any good applications that will capture my ps2 linked through the ati rage theater?
EDIT** have managed to get a good picture on using the composite adaptor, colour aswell AND sound, but picture is so bad, i am now using it through the tv tuner, anyway to improve the quality of the picture?
Do you have an S-video cable, that’s the recommended way, it ends up looking a bit better than composite on a TV at least. Give it a try.
i am using it through the computer, linked through tv tuner, i am using this yellow thing, i will try s-video, dont think it wrks though.
