hi guys, i know a hell of a lot about pc’s and peripherals (i fixed them for a living) but i don’t know much about networking (except a bit of peer to peer) and i would like to use VoIP i have a Hayes ethernet router, Xyzel Prestige P2002, a Netgear FA 311 ethernet card, onboard SiS 900 PCI (in thne same machine) and a cheap switch, i have access to the web configuration pages for both devices, as for o\s take your pick win98, me, xp i have miltiple bootable partitions, all i have to do is convert a partition to primary and set it active
I dont understand what the problem is!
Are you looking for suggestions as to which service to use?
i think he wants to know how to create VOIP connection…
This tells you about how internet VOIP works
http://www.fcc.gov/cgb/consumerfacts/voip.html
or VoIP Howto
thank you i’ll check out those websites and keep you updated, thanks
