weird problem
Hi
I am facing the weirdest problem in win2k+sp4. i did a fresh install on a different partition then installed all the needed drivers etc. I was trying to install Ulead video 9, it asked me to restart but wheneveri came back into windows i didnt see the mouse pointer, no mousse. i tried with diffrent mouse but no luck. so i took off ulead video studio and restarted and pointer came back. Again i installed antivirus the pointer disappeard.
weird aye!. what to do?.
what AV u using ?
avast is great (in my sig), also scan with Ad-aware (personal edition is free)
Are you using any custom mouse pointer? or theming program which set’s your cursor image?
i have nod32 & sygate firewall. installed & no i dont hav any custom cursors.
try downloading a newer version of sygate (i think this is the latest)
now uninstall sygate, reboot and install the new one
is all ok ?
if not then do the same with Nod32 AV
is all ok ?
