what would need to be in a pc to make farcry and some other FPS games work well?
A good video card 9800pro 256-bit, fast processor >amd athlon 2400+, good ram about 512mb of it too.
It would depend on how much you willing to spend really! You can get a budget graphics card etc and the games will work fine, however if you want to play the games on high detail then you will need quite a powerful pc.
I would recommend a good prcessor (around 2.0Ghz) and a good Graphics (these days 9800pro) card and lots of RAM.
These specs. might look a little high but personally speaking I hate if there is any kind of lag problem with my FPS.
Are there any models from manufacturers that u would recommend because
I don’t have time to build one
alienware is one, not my fav but im drawring a blank
Duplicate thread.
Closed. Next time, only post in one section.
