What kind of memory will work best?
Inter(R) Pentium(R) 4 CPU 1.80GHz that is the type of computer i got i dont know what kind of memory to get? i would like to get 1gb or a 512mb for the cheapest so i can run bf2 better.
What you are gonna get depends on your budget but…
Your ram is most likely pc3200. Hear is a good/cheap 1 gig stick
http://www.newegg.com/Product/Product.asp?Item=N82E16820211130
Here is a really good 512mb stick
http://www.newegg.com/Product/Product.asp?Item=N82E16820220018
[QUOTE=Warmonger41]
how do i know if its a pc 3200 or not ?
You need to find out what type of RAM your motherboard supports. At a guess, i’d say its going to be DDR PC2700 and PC3200.
I’d recommend you get 1GB of RAM, especially if you plan to upgrade to Vista later on
just found this
