I need a good CPU for my new mainboard (ASUS A8V Deluxe) and I have my eyes on these 2.
The difference in cost is only 20,- euro but is there a special reason why I should take a particular one.
In the specs I only noticed that the top one has SSE3 :sick: (whatever that may be)
I’d like to know which one I should choose, or shouldn’t I buy any of these two, should I buy a completely different cpu?
the difference i can spot is that the san diego has sse3, which to my knowledge is a built in “setting” that can imrpove performance when running applications that support it, eg counterstrike source supports “3dNow!” coding, if you turn it on in game (r_3dnow 1).
also note that the san diego is a newer chip, and so therefore will be better to get, and for only 20 euros, cant go wrong.
Yeah, go with the SanDiego, once overclocked, if you’re into that, to 2.6 GHz it will be faster than the FX 55 and still be cooler:good:. With that minimal a price difference go with the best.
Overclocking is usually easier with the P4 chips because of NetBurst, however AMD CPUs can still be overclocked. Read an overclocking guide and it will tell you to go in small increments only and step back from the max clock your CPU will take. As long as you have a good cooler and you’re sensible your CPU should be fine.
