W7Pro is suppose to only take up to 16 Gigs according to Google.
I havn’t even installed drivers, I"m sitting on some insanely ugly resolution typing this right now. I have 62 Gigs out of 111 Gigs free. What could possibly be causing 50 gigs to not appear?
It is a 120 Gig drive (SSD).
Also, I’m starting to think I should leave my SSD for Games only, and install the OS on a different hard drive. Unless having the OS on a different Hard Drive will impact performance.
I cleared the OS completely, and formatted the drive. It created a System Reserve, but that was only 100 MB.
Same thing happened when I got the drive brand new (Nothing ever on it). So I redid it thinking I may of done something stupid, but I did everything right it seems.
Figured it out.
The Hibernation file was 18 gigs alone.
Ontop of that, because I have 24 gigs of RAM, it created a Virtual Memory pool of about 30 gigs.
If you havn’t done so already, you should disable windows write caching on the drive, write caching will GREATLY reduce the performance of SSD drives.
if you dont put your OS on your ssd you should definately put your page file on it. Putting your page file on a solid state disk will greatly increase performance
Well, besides the point that this thread is from 2011, I posted the problem above. It was because I have 24 gigs of RAM, and windows automatically thinks you need more virtual RAM to support it! (For some reason)
Its sorted out, just had to reduce my virtual RAM.
