wich CPU is Better
AMD A10-5800K Trinity 3.8GHz Socket FM2 Quad-Core Desktop APU
or
Intel Core i3- 3210 3.3 GHz/ 6MB cache
Please help
It all depends On what you will be using the computer for !! I prefer the i3, But the i7 would be the best..
yeah sure the i7 is the best, but Expensive..i’ll use the computer for gaming
Depending on what Motherboard you choose the i3 would be better, Plus you can overclock the i3 to like 3.8 ghz..
Thanks alot. so wich motherBoard is better for the i3.. Asus, MSI or Gigabyte?
Gigabyte , then Asus , and MSI
The graphics are better with the A10-5800K, so if you can’t spring for a separate video card, that would be your best bet. Also, this is the chip to get if you’d like to play around with CPU overclocking as the multiplier is unlocked.
The i3’s graphics are basic performance, so if you don’t have a video card, don’t expect much here.
If you have or plan on purchasing a video card and don’t care about overclocking, go with whatever chip is cheapest.
thanks alot , that will help. Last thing..what if i get SAPHIRE HD 7750 1GB DDr5 vedio card on the i3
would it be good for games like Battlefiled 3 ?
It seems to run alright with my 6750, so I’d imagine there’s a few performance tweaks for the 7750 that might smooth it out a tad. I highly doubt it’s any worse. However, an quick peek at the next step up, the Radeon 7790 is better and practically the same price, at least according to Newegg’s prices. You have plenty of options under $120, and the 7750 is right around $100-110, so it’s worth a shot.
Also, I’d imagine that i3 is probably a bit better than my Pentium E2160, so that should help as well.
id say asus first, have one in the rig im using now…never have had one complaint bout it
Well we all have our own Opinion..But I will Stay with mine And 20 years of Experience…
