Wierd Display Mode On ATI 9250
After years of using Intel CPU’s some months ago i changed to AMD, and now i’ve finaly converted to ATI!
While i’m happy with my Radeon 9250 (ASUS A9250-one of those quick fix jobs) when i change the resolution to 1152x864 (which is my maximum supported screen res), it doesnt fit the desktop properly on my screen, to view the desktop i have to move my cursor to the edges (or scrolling in a sense) to see the rest!
Now i am using the original drivers that came with my card at the moment and have also tried the latest Omega drivers and the Latest Catalyst drivers with no change!
Ideally i just want to view my WHOLE desktop at 1152x864 without having to scroll!
Any ideas on how to overcome this?
[QUOTE=pelvis_3]
Sound like your monitor doesn’t support that resolution.
Even though the rated max is 1024x768 it works on 1152x864 on my GeForce FX5200 and my old GeForce 2 MX400!
Any Ideas?
dont you have buttons on the front of your monitor and an on screen display for adjusting the actual screen size, becouse i havent heard of any monitor with a max supported reseloution of 1152864, my 15" crt has a maxreported reseloution of 20481536, but it only works up to 1600*1200.
mine is ok up to 1280*1024.
I have fiddled with the buttons on the monitor but then it puts the desktop in the center of the screen and i still have to scroll, but then the writing is too small!
oh :s, i am lost then :s, looks like you just need a new crt, i got mine for £10 second hand becouse the focus failed on my old monitor.
I am planning on getting a 17" TFT soon but for now i just want my 1152x864 back!
As i said in a previous post that resolution worked perfectly on both my FX5200 and my MX400 cards!
Is this just an ATI thing perhaps?
use your tv if you have a decent one, those reseloutions are really bad anyway, i can stand less than my max screen res :frowning:
I will try it on my TV ASAP!
I also can’t stand less than my max supported res!
Currently i’m sittin’ on 1024 and on a 15" monitor everything is HUGE!
I really want my 1152x864 back :frowning:
