Windows 2000 pro problem
Hi, i have Visual Basic 6 enterprise edition on a virtual drive on my main comp, i shared this virtual drive on the network, went to my old comp and installed it, needed some java thing installing, after that it needed to reboot, and when windows started again, it never loaded, just got the the windows 2000 loading window were it said prepairing network connections, stayed on that for ages, now i am on a screen asking for username and password, there allready in, i cant do anything, i cant even press ok :s, anyone know whats up?
I dont know much about Win2k and about ur problem but u can try one thing. Try booting ur computer in Safe mode and see if you can get admin rights to enter into system and do system restore or use the last known working status…
cant, had to restore, went with windows xp instead.
