Wine Issue
I try to run a .exe from the terminal but it brings up an error message:
rjcube@rjcube-desktop:~$ wine /mnt/vcd1/install.exe Warning: the specified Windows directory L"c:\\windows" is not accessible. Warning: the specified System directory L"c:\\windows\\system32" is not accessible. Warning: could not find DOS drive for current working directory '/home/rjcube', starting in the Windows directory. wine: cannot find '/mnt/vcd1/install.exe'
How can I get this file running?
Thank you in advance for any help.
Hey Rjcube
Have you configured the virtual Windows drives in WINE yet?
just type:
winecfg
And check it’s all set up properly.
Also, Wine Tools can do this for you.
[QUOTE=megamaced]
Hey Rjcube
just type:
winecfg
What directory would I need to set the virtual C Drive to?
btw, thats the best error message ever: You do not have a C Drive. This is not so great.
Wine will set the directory for you.
I think it’s normally located at
~/.wine/
BTW, you may want to check out Wine Doors. It’s a brand new project set up to replace the aging Wine Tools.
Wine tools helpped me install the virtul drive and the files run now, thanks allot once again mega, ur always a huge help.
BTW, the version of WINE in the Ubuntu repositories is quite old. Newer versions can be downloaded by adding:
deb http://wine.budgetdedicated.com/apt dapper main
Into your sources.list file.
Then
apt-get update
Followed by
apt-get install wine
I tried to configure WINE ealier today with WineTools and it was an absolute nightmare! WineTools is really showing it’s age and it doesn’t even work properly with the lastest WINE version. The new WineDoors project looks promising, but they haven’t made a release yet!
[QUOTE=megamaced]
Then
apt-get update
Followed by
I tried to configure WINE ealier today with WineTools and it was an absolute nightmare! WineTools is really showing it’s age and it doesn’t even work properly with the latest WINE version. The new WineDoors project looks promising, but they haven’t made a release yet!
Sweet, thanks for the update.
Also, I agree that WineDoors looks pretty promising too, I shall be looking forward to the release.
