Winxp sp2 start up problem
When I start up Windows. I get a small window at the begining that says
“Windows can not find “******* ******* n**” Make sure you typed the name correctly, and then try again. To search for a file, click the start button and then click search.”
I click OK and then another small window comes up and says.
“Could not load or run ******* ******* n**” soecifies in the registry.Make sure the file exists on your computer or remove the reference to it in the registry."
I click OK again and then windows finishes loading and things run fine.This happens everytime I start up windows. Is there any way of getting rid of these
messages at start up. Please help if you can
P.S. The * are actually squares that show up.
Thank You
Something’s damaged a windows file or registry entry. try doing a repair install of windows which will fix it, but you may want to slipstream SP2 with XP so you don’t have to reinstall SP2.
The computer I am using is a HP. If I use the recover disk will that help.
Yea, use the recovery disc and you should be ok.
Thanks for your help. I will do that.
