wireless broad band help needed
[SIZE=“3”]Hi to all, i am new to this forum and i need help from the experts please.
i have just had a lap top and i want to be wireless i am currently using the yellow lead to connect to the internet. I am with BT and i have a bt voyager modem it is not wireless, i have been given a sky wireless modem it is made by netgear can i use this if i can how do i set it up. If you can not already tell i am useless with this techy stuff sorry !!![/SIZE]
which laptop is it? because first, we need to check if it has a wireless device fitted.
It is a toshiba tecra t9100
Google search didn’t reveal much information but it does look like the laptop doesn’t have inbuilt wireless. What you need is USB wireless adapter, something like Netgear WG111 Wireless 54Mbps USB 2.0 Adapter: Electronics & Photo: Amazon.co.uk which should come with software that includes a setup wizard.
It does have wireless, according to this ZDNet page. Also, an unofficial one here (someone selling). There is no more such a thing as laptops sold without a wireless adapter built in, is there??
You could try this software Easy WiFi Radar…
Manual - Easy WIFI Radar
Hi
You should be able to use the Sky modem but I’d like to suggest something if you would not mind…
First, get a better wireless adapter. The laptop according to ZDnet uses 802.11b which has been now superseded by 802.11g. With prices of USB adapters ever falling you can get a decent one for about £20.
That is not all… In order to use the Netgear modem/wireless router you will need to mimic the connection settings from the BT modem so when you fire your Netgear up it will connect to your ISP. Have you ever logged in to your BT modem?
This is normally done by typing 192.168.0.1 into the Internet explorer address field. Then you might have to use a username and password to log in to the modem.
Here is the webpage of the hardware I think you have (I am a SKY customer and that is the one I have) Support Page
Check the installation guide and the refrence manuall and see if that gives you an idea…
Let us know how you get on with getting the connection settings from the BT modem :cool:
