Hello,
I recently purchased 1 wireless router and 2 wireless PCI adapters. I have installed everything, including the drivers.
One computer can connect to the router perfectly, I can modify/view the router settings.
However, the other computer can connect to the router, but once connected it only stays connected for 5-10 seconds and then comes up with the message reading: “connection unavailable.” When it is connected for the 5-10seconds it says the signal strength is excellent.
I have checked the settings on both computers and they are the same, they are both operating on Windows XP also.
What do I need to do for the other computer to hold it’s connection to the router?
Thanks in advance.
