X-Fi Sound Card
Hey,
  I just formatted my PC.  I install my x-fi sound card.  It installs and everything, but the panel for the x-fi does not show up on my start bar (at the bottom of my screen where the time is shown).  How can I make it show up on there.  by panel I mean where you can see the equalizers and everything like that.
Usually something like that can be found under the sound settings under the control panel, if you can’t find anything try re-installing!
I think the X-Fi cd gives you a number of options during install, If so choose “full” and continue installing, this should fix the issue!
Thanks a lot .. I reinstalled everything and it worked!
