X wont load upon reboot
So since I almost never reboot my system, I dont know how long this problem has been going on, but when I do reboot, my system (Debian etch), does not boot into X. It just hangs on the blank screen. Nvidia is working fine and no matter how many times I restart kdm, it is still the same problem. The only way I have found to get back into X is to install the nvidia drivers again and then start kdm. After I do this, my nvidia drivers continue to work just like they normally would, as long as I dont reboot. I dont know if anyone else here is having this problem, but I certainly am.
After googling the problem for a bit, I managed to find someone who had the problem and was able to “solve it” with a script he wrote. I say “solve” because it doesn’t work for me at all (btw, he is running Debian etch also). Here is his instructions followed by a link to the original:
Original = nvidia works after build but not after reboot-Debian Linux Help-Linux Forums
Ok, so anybody have any ideas on how to fix this… its not a huge problem because I almost never reboot, but I still think it is a problem that I shouldn’t have to deal with and shouldn’t exist
I’m gona join you with this one…
I installed the nvidia drivers with automatix, but found them to be jumpy… so i downloaded and installed the current drivers from nvidia (and then killall gdm, sh NVIDIA-Linux-x86-… )
It complained and said that i needed to install the “x.org sdk/development” packages for my distribution… gave a load of other errors which i now cant remember now, when i install the x.org sdk it stopped complaining when i re-installed the drivers.
I’ve :swear: this one up at levels normally reserved for George Bush, any advice?
I’m not sure about the answer to your problem… in fact, I’m not quite sure what your problem is- one of your last lines is that it “stopped complaining” when you re-installed the drivers. Which gives me the impression that everything is fine now. What did I miss?
And my second piece of business is to encourage people around the HWF to help me figure out what is going wrong with my system.. I’d even be relieved to find out that some of you other Debian-etchers have the same problem (though I dont wish it upon you).
I haven’t had any problems at all with X and the latest stable release of the NVidia binaries, but then again my workstation has been up for 50 days now, so… :open_mouth:
…come to think of it, did you migrate to Etch from Sarge? There was some /dev/ stuff in Sarge that was obsoleted in Etch, and during some recent updates, dpkg “noticed” them and told me to remove them in less than polite terms. :slight_smile:
The installer stopped complaining, and i can start x (startx) afterwards and it all works fine untill i restart :confused: (after i’ve restarted startx fails)
I’m using the 9xxx drivers, and sometimes when X starts the resolution will be very low, although KDM works fine. I fix it by restarting X via the menu item.
This doesn’t always happen, which is strange.
Yeah, i didn’t realize that mine wasn’t working either.. the first time I noticed it was maybe a week ago (i had to shut it down to move my computer), and my uptime at that point was 41 days… so I dont know… maybe it is because of a recent update.
As far as to etch from sarge, the answer is no. I installed etch fresh – straight from the cd onto a freshly formatted drive. So Sarge definitely shouldn’t have anything to do with it. But either way, help would be appreciated. And lately, it is especially obnoxious because I am in the process of moving so my system is being booted and shutdown fairly often while it is being physically moved and while im dealing with internet issues.
OK, OK, so I rebooted just to prove that it wasn’t a Debian-specific issue (bye bye, 53+ day uptime!) Guess what? Booted right to X, pretty NVidia splash screen and everything. So in conclusion, whatever is going on isn’t as widespread as you think. Let’s start out with some log files, both /var/log/X.org.xxxx and /var/log/messages, and your x.org.conf wouldn’t hurt either. :slight_smile:
I have /var/log/Xorg.1.log and Xorg.0.log… both of which are pretty long. Here is Xorg.1.log. Boy, this is going to be long: [code]$ :/var/log$ cat Xorg.1.log
X Window System Version 7.0.0
Release Date: 21 December 2005
X Protocol Version 11, Revision 0, Release 7.0
Build Operating System:Linux 2.6.12-1-686 i686
Current Operating System: Linux joe01 2.6.17-2-486 #1 Wed Sep 13 15:56:30 UTC 2006 i686
Build Date: 16 March 2006
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Module Loader present
Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: “/var/log/Xorg.1.log”, Time: Wed Oct 11 19:38:45 2006
(==) Using config file: “/etc/X11/xorg.conf”
(==) ServerLayout “Default Layout”
) |–>Screen “Default Screen” (0)
() | |–>Monitor “SyncMaster”
) | |–>Device “NVIDIA 7900gt”
() |–>Input Device “Generic Keyboard”
) |–>Input Device “Configured Mouse”
(WW) The directory “/usr/X11R6/lib/X11/fonts/misc” does not exist.
Entry deleted from font path.
(WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/cyrillic” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/100dpi/” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/75dpi/” does not exist.
(WW) fonts.dir' not found (or not valid) in "/usr/share/fonts/X11/Type1". Entry deleted from font path. (Run 'mkfontdir' on "/usr/share/fonts/X11/Type1"). (WW) The directory "/usr/X11R6/lib/X11/fonts/Type1" does not exist. Entry deleted from font path. (WW) The directory "/usr/X11R6/lib/X11/fonts/100dpi" does not exist. Entry deleted from font path. (WW) The directory "/usr/X11R6/lib/X11/fonts/75dpi" does not exist. Entry deleted from font path. (WW) fonts.dir’ not found (or not valid) in “/var/lib/defoma/x-ttcidfont-conf.d/dirs/CID”.
(Run ‘mkfontdir’ on “/var/lib/defoma/x-ttcidfont-conf.d/dirs/CID”).
(WW) The directory “/usr/local/share/fonts/truetype” does not exist.
(WW) The directory “/usr/lib/X11/fonts/CID” does not exist.
(WW) The directory “/usr/lib/X11/fonts/Speedo” does not exist.
(WW) The directory “/usr/lib/X11/fonts/misc” does not exist.
(WW) The directory “/usr/lib/X11/fonts/cyrillic” does not exist.
(WW) The directory “/usr/lib/X11/fonts/100dpi” does not exist.
(WW) The directory “/usr/lib/X11/fonts/75dpi” does not exist.
(WW) The directory “/usr/lib/X11/fonts/Type1” does not exist.
(**) FontPath set to “/usr/share/fonts/X11/misc,/usr/share/fonts/X11/100dpi/:unscaled,/usr/share/fonts/X11/75dpi/:unscaled,/usr/share/fonts/X11/100dpi,/usr/share/fonts/X11/75dpi,/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType,/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType,/usr/share/fonts/truetype,/usr/share/fonts/X11/misc/,/usr/share/fonts/X11/TTF/,/usr/share/fonts/X11/OTF,/usr/share/fonts/X11/Type1/,/usr/share/fonts/X11/CID/,/usr/share/fonts/X11/100dpi/,/usr/share/fonts/X11/75dpi/”
(==) RgbPath set to “/usr/share/X11/rgb”
(==) ModulePath set to “/usr/lib/xorg/modules”
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.2
X.Org Video Driver: 0.8
X.Org XInput driver : 0.5
X.Org Server Extension : 0.2
X.Org Font Renderer : 0.4
(II) Loader running on linux
(II) LoadModule: “bitmap”
(II) Loading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) Module bitmap: vendor=“X.Org Foundation”
compiled for 7.0.0, module version = 1.0.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.4
(II) Loading font Bitmap
(II) LoadModule: “pcidata”
(II) Loading /usr/lib/xorg/modules/libpcidata.so
(II) Module pcidata: vendor=“X.Org Foundation”
ABI class: X.Org Video Driver, version 0.8
(++) using VT number 8
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 1106,0238 card 147b,1416 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:00:1: chip 1106,1238 card 0000,0000 rev 00 class 06,00,00 hdr 00
(II) PCI: 00:00:2: chip 1106,2238 card 0000,0000 rev 00 class 06,00,00 hdr 00
(II) PCI: 00:00:3: chip 1106,3238 card 0000,0000 rev 00 class 06,00,00 hdr 00
(II) PCI: 00:00:4: chip 1106,4238 card 0000,0000 rev 00 class 06,00,00 hdr 00
(II) PCI: 00:00:5: chip 1106,5238 card 0000,0000 rev 00 class 08,00,20 hdr 80
(II) PCI: 00:00:7: chip 1106,7238 card 0000,0000 rev 00 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 1106,b188 card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:02:0: chip 1106,a238 card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:03:0: chip 1106,c238 card 0000,0000 rev 00 class 06,04,00 hdr 81
(II) PCI: 00:03:1: chip 1106,d238 card 0000,0000 rev 00 class 06,04,00 hdr 81
(II) PCI: 00:03:2: chip 1106,e238 card 0000,0000 rev 00 class 06,04,00 hdr 81
(II) PCI: 00:03:3: chip 1106,f238 card 0000,0000 rev 00 class 06,04,00 hdr 81
(II) PCI: 00:07:0: chip 1106,3044 card 147b,1416 rev 46 class 0c,00,10 hdr 00
(II) PCI: 00:08:0: chip 10ec,8139 card 10ec,8139 rev 10 class 02,00,00 hdr 00
(II) PCI: 00:09:0: chip 1102,0004 card 1102,2002 rev 04 class 04,01,00 hdr 80
(II) PCI: 00:09:1: chip 1102,7003 card 1102,0040 rev 04 class 09,80,00 hdr 80
(II) PCI: 00:09:2: chip 1102,4001 card 1102,0010 rev 04 class 0c,00,10 hdr 80
(II) PCI: 00:0c:0: chip 1106,3249 card 147b,1416 rev 50 class 01,04,00 hdr 00
(II) PCI: 00:0e:0: chip 13f0,1023 card 147b,1416 rev 41 class 02,00,00 hdr 00
(II) PCI: 00:0f:0: chip 1106,3149 card 147b,1416 rev 80 class 01,04,00 hdr 80
(II) PCI: 00:0f:1: chip 1106,0571 card 147b,1416 rev 06 class 01,01,8a hdr 00
(II) PCI: 00:10:0: chip 1106,3038 card 147b,1416 rev 81 class 0c,03,00 hdr 80
(II) PCI: 00:10:1: chip 1106,3038 card 147b,1416 rev 81 class 0c,03,00 hdr 80
(II) PCI: 00:10:2: chip 1106,3038 card 147b,1416 rev 81 class 0c,03,00 hdr 80
(II) PCI: 00:10:3: chip 1106,3038 card 147b,1416 rev 81 class 0c,03,00 hdr 80
(II) PCI: 00:10:4: chip 1106,3104 card 147b,1416 rev 86 class 0c,03,20 hdr 80
(II) PCI: 00:11:0: chip 1106,3227 card 147b,1416 rev 00 class 06,01,00 hdr 80
(II) PCI: 00:18:0: chip 1022,1100 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:1: chip 1022,1101 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:2: chip 1022,1102 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:3: chip 1022,1103 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 02:00:0: chip 10de,0291 card 10de,0321 rev a1 class 03,00,00 hdr 00
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,6), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x0010 (VGA_EN is cleared)
(II) Bus 1 I/O range:
[0] -1 0 0x0000b000 - 0x0000bfff (0x1000) IX[B]
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xdfb00000 - 0xdfbfffff (0x100000) MX[B]
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xdfa00000 - 0xdfafffff (0x100000) MX[B]
(II) Bus 2: bridge is at (0:2:0), (0,2,2), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 2 I/O range:
[0] -1 0 0x0000a000 - 0x0000afff (0x1000) IX[B]
(II) Bus 2 non-prefetchable memory range:
[0] -1 0 0xdd000000 - 0xdeffffff (0x2000000) MX[B]
(II) Bus 2 prefetchable memory range:
[0] -1 0 0xb0000000 - 0xcfffffff (0x20000000) MX[B]
(II) Bus 3: bridge is at (0:3:0), (0,3,3), BCTRL: 0x0000 (VGA_EN is cleared)
(II) Bus 3 I/O range:
[0] -1 0 0x00009000 - 0x00009fff (0x1000) IX[B]
(II) Bus 3 prefetchable memory range:
[0] -1 0 0xdf800000 - 0xdf8fffff (0x100000) MX[B]
(II) Bus 4: bridge is at (0:3:1), (0,4,4), BCTRL: 0x0000 (VGA_EN is cleared)
(II) Bus 4 I/O range:
[0] -1 0 0x00008000 - 0x00008fff (0x1000) IX[B]
(II) Bus 4 prefetchable memory range:
[0] -1 0 0xdf600000 - 0xdf6fffff (0x100000) MX[B]
(II) Bus 5: bridge is at (0:3:2), (0,5,5), BCTRL: 0x0000 (VGA_EN is cleared)
(II) Bus 5 I/O range:
[0] -1 0 0x0000d000 - 0x0000dfff (0x1000) IX[B]
(II) Bus 5 prefetchable memory range:
[0] -1 0 0xdfe00000 - 0xdfefffff (0x100000) MX[B]
(II) Bus 6: bridge is at (0:3:3), (0,6,6), BCTRL: 0x0000 (VGA_EN is cleared)
(II) Bus 6 I/O range:
[0] -1 0 0x0000c000 - 0x0000cfff (0x1000) IX[B]
(II) Bus 6 prefetchable memory range:
[0] -1 0 0xdfc00000 - 0xdfcfffff (0x100000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:17:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(–) PCI:*(2:0:0) nVidia Corporation unknown chipset (0x0291) rev 161, Mem @ 0xdd000000/24, 0xb0000000/28, 0xde000000/24, I/O @ 0xaf00/7
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0 0xffe00000 - 0xffffffff (0x200000) MXB
[1] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[2] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[3] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[4] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[5] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[6] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) PCI Memory resource overlap reduced 0xd0000000 from 0xd7ffffff to 0xcfffffff
(II) Active PCI resource ranges:
[0] -1 0 0xdfffb000 - 0xdfffb0ff (0x100) MX[B]
[1] -1 0 0xdfffc000 - 0xdfffc0ff (0x100) MX[B]
[2] -1 0 0xdfff4000 - 0xdfff7fff (0x4000) MX[B]
[3] -1 0 0xdfffd000 - 0xdfffd7ff (0x800) MX[B]
[4] -1 0 0xdfffe000 - 0xdfffe0ff (0x100) MX[B]
[5] -1 0 0xdffff000 - 0xdffff7ff (0x800) MX[B]
[6] -1 0 0xd0000000 - 0xcfffffff (0x0) MX[B]O
[7] -1 0 0xde000000 - 0xdeffffff (0x1000000) MXB
[8] -1 0 0xb0000000 - 0xbfffffff (0x10000000) MXB
[9] -1 0 0xdd000000 - 0xddffffff (0x1000000) MXB
[10] -1 0 0x0000ee00 - 0x0000ee1f (0x20) IX[B]
[11] -1 0 0x0000ef00 - 0x0000ef1f (0x20) IX[B]
[12] -1 0 0x0000f000 - 0x0000f01f (0x20) IX[B]
[13] -1 0 0x0000f100 - 0x0000f11f (0x20) IX[B]
[14] -1 0 0x0000f200 - 0x0000f20f (0x10) IX[B]
[15] -1 0 0x0000e800 - 0x0000e8ff (0x100) IX[B]
[16] -1 0 0x0000f300 - 0x0000f30f (0x10) IX[B]
[17] -1 0 0x0000f400 - 0x0000f403 (0x4) IX[B]
[18] -1 0 0x0000f500 - 0x0000f507 (0x8) IX[B]
[19] -1 0 0x0000f600 - 0x0000f603 (0x4) IX[B]
[20] -1 0 0x0000f700 - 0x0000f707 (0x8) IX[B]
[21] -1 0 0x0000e600 - 0x0000e6ff (0x100) IX[B]
[22] -1 0 0x0000ea00 - 0x0000eaff (0x100) IX[B]
[23] -1 0 0x0000f800 - 0x0000f81f (0x20) IX[B]
[24] -1 0 0x0000f900 - 0x0000f90f (0x10) IX[B]
[25] -1 0 0x0000fa00 - 0x0000fa0f (0x10) IX[B]
[26] -1 0 0x0000fb00 - 0x0000fb0f (0x10) IX[B]
[27] -1 0 0x0000fc00 - 0x0000fc0f (0x10) IX[B]
[28] -1 0 0x0000fd00 - 0x0000fd07 (0x8) IX[B]
[29] -1 0 0x0000fe00 - 0x0000fe3f (0x40) IX[B]
[30] -1 0 0x0000ec00 - 0x0000ecff (0x100) IX[B]
[31] -1 0 0x0000ff00 - 0x0000ff7f (0x80) IX[B]
[32] -1 0 0x0000af00 - 0x0000af7f (0x80) IXB
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[5] -1 0 0xdfffb000 - 0xdfffb0ff (0x100) MX[B]
[6] -1 0 0xdfffc000 - 0xdfffc0ff (0x100) MX[B]
[7] -1 0 0xdfff4000 - 0xdfff7fff (0x4000) MX[B]
[8] -1 0 0xdfffd000 - 0xdfffd7ff (0x800) MX[B]
[9] -1 0 0xdfffe000 - 0xdfffe0ff (0x100) MX[B]
[10] -1 0 0xdffff000 - 0xdffff7ff (0x800) MX[B]
[11] -1 0 0xd0000000 - 0xcfffffff (0x0) MX[B]O
[12] -1 0 0xde000000 - 0xdeffffff (0x1000000) MXB
[13] -1 0 0xb0000000 - 0xbfffffff (0x10000000) MXB
[14] -1 0 0xdd000000 - 0xddffffff (0x1000000) MXB
[15] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[16] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[17] -1 0 0x0000ee00 - 0x0000ee1f (0x20) IX[B]
[18] -1 0 0x0000ef00 - 0x0000ef1f (0x20) IX[B]
[19] -1 0 0x0000f000 - 0x0000f01f (0x20) IX[B]
[20] -1 0 0x0000f100 - 0x0000f11f (0x20) IX[B]
[21] -1 0 0x0000f200 - 0x0000f20f (0x10) IX[B]
[22] -1 0 0x0000e800 - 0x0000e8ff (0x100) IX[B]
[23] -1 0 0x0000f300 - 0x0000f30f (0x10) IX[B]
[24] -1 0 0x0000f400 - 0x0000f403 (0x4) IX[B]
[25] -1 0 0x0000f500 - 0x0000f507 (0x8) IX[B]
[26] -1 0 0x0000f600 - 0x0000f603 (0x4) IX[B]
[27] -1 0 0x0000f700 - 0x0000f707 (0x8) IX[B]
[28] -1 0 0x0000e600 - 0x0000e6ff (0x100) IX[B]
[29] -1 0 0x0000ea00 - 0x0000eaff (0x100) IX[B]
[30] -1 0 0x0000f800 - 0x0000f81f (0x20) IX[B]
[31] -1 0 0x0000f900 - 0x0000f90f (0x10) IX[B]
[32] -1 0 0x0000fa00 - 0x0000fa0f (0x10) IX[B]
[33] -1 0 0x0000fb00 - 0x0000fb0f (0x10) IX[B]
[34] -1 0 0x0000fc00 - 0x0000fc0f (0x10) IX[B]
[35] -1 0 0x0000fd00 - 0x0000fd07 (0x8) IX[B]
[36] -1 0 0x0000fe00 - 0x0000fe3f (0x40) IX[B]
[37] -1 0 0x0000ec00 - 0x0000ecff (0x100) IX[B]
[38] -1 0 0x0000ff00 - 0x0000ff7f (0x80) IX[B]
[39] -1 0 0x0000af00 - 0x0000af7f (0x80) IXB
(II) LoadModule: “i2c”
(II) Loading /usr/lib/xorg/modules/libi2c.so
(II) Module i2c: vendor=“X.Org Foundation”
compiled for 7.0.0, module version = 1.2.0
(II) Reloading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) LoadModule: “ddc”
(II) Loading /usr/lib/xorg/modules/libddc.so
(II) Module ddc: vendor=“X.Org Foundation”
(II) LoadModule: “extmod”
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Module extmod: vendor=“X.Org Foundation”
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 0.2
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: “freetype”
(II) Loading /usr/lib/xorg/modules/fonts/libfreetype.so
(II) Module freetype: vendor=“X.Org Foundation & the After X-TT Project”
compiled for 7.0.0, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: “glx”
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(II) Module glx: vendor=“NVIDIA Corporation”
compiled for 4.0.2, module version = 1.0.8774
ABI class: X.Org Server Extension, version 0.1
(II) Loading extension GLX
(II) LoadModule: “int10”
(II) Loading /usr/lib/xorg/modules/libint10.so
(II) Module int10: vendor=“X.Org Foundation”
(II) LoadModule: “type1”
(II) Loading /usr/lib/xorg/modules/fonts/libtype1.so
(II) Module type1: vendor=“X.Org Foundation”
compiled for 7.0.0, module version = 1.0.2
(II) Loading font Type1
(II) LoadModule: “vbe”
(II) Loading /usr/lib/xorg/modules/libvbe.so
(II) Module vbe: vendor=“X.Org Foundation”
compiled for 7.0.0, module version = 1.1.0
(II) LoadModule: “nvidia”
(II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.o
(II) Module nvidia: vendor=“NVIDIA Corporation”
Module class: X.Org Video Driver
(II) LoadModule: “kbd”
(II) Loading /usr/lib/xorg/modules/input/kbd_drv.so
(II) Module kbd: vendor=“X.Org Foundation”
compiled for 7.0.0, module version = 1.0.1
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 0.5
(II) LoadModule: “mouse”
(II) Loading /usr/lib/xorg/modules/input/mouse_drv.so
(II) Module mouse: vendor=“X.Org Foundation”
compiled for 7.0.0, module version = 1.0.4
(II) NVIDIA X Driver 1.0-8774 Tue Aug 1 20:56:50 PDT 2006
(II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
(II) Primary Device is: PCI 02:00:0
(–) Assigning device section with no busID to primary device
(–) Chipset NVIDIA GPU found
(II) Loading sub module “fb”
(II) LoadModule: “fb”
(II) Loading /usr/lib/xorg/modules/libfb.so
(II) Module fb: vendor=“X.Org Foundation”
ABI class: X.Org ANSI C Emulation, version 0.2
(II) Loading sub module “ramdac”
(II) LoadModule: “ramdac”
(II) Loading /usr/lib/xorg/modules/libramdac.so
(II) Module ramdac: vendor=“X.Org Foundation”
compiled for 7.0.0, module version = 0.1.0
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
[15] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[16] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[17] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[18] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[19] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[20] -1 0 0x0000ee00 - 0x0000ee1f (0x20) IX[B]
[21] -1 0 0x0000ef00 - 0x0000ef1f (0x20) IX[B]
[22] -1 0 0x0000f000 - 0x0000f01f (0x20) IX[B]
[23] -1 0 0x0000f100 - 0x0000f11f (0x20) IX[B]
[24] -1 0 0x0000f200 - 0x0000f20f (0x10) IX[B]
[25] -1 0 0x0000e800 - 0x0000e8ff (0x100) IX[B]
[26] -1 0 0x0000f300 - 0x0000f30f (0x10) IX[B]
[27] -1 0 0x0000f400 - 0x0000f403 (0x4) IX[B]
[28] -1 0 0x0000f500 - 0x0000f507 (0x8) IX[B]
[29] -1 0 0x0000f600 - 0x0000f603 (0x4) IX[B]
[30] -1 0 0x0000f700 - 0x0000f707 (0x8) IX[B]
[31] -1 0 0x0000e600 - 0x0000e6ff (0x100) IX[B]
[32] -1 0 0x0000ea00 - 0x0000eaff (0x100) IX[B]
[33] -1 0 0x0000f800 - 0x0000f81f (0x20) IX[B]
[34] -1 0 0x0000f900 - 0x0000f90f (0x10) IX[B]
[35] -1 0 0x0000fa00 - 0x0000fa0f (0x10) IX[B]
[36] -1 0 0x0000fb00 - 0x0000fb0f (0x10) IX[B]
[37] -1 0 0x0000fc00 - 0x0000fc0f (0x10) IX[B]
[38] -1 0 0x0000fd00 - 0x0000fd07 (0x8) IX[B]
[39] -1 0 0x0000fe00 - 0x0000fe3f (0x40) IX[B]
[40] -1 0 0x0000ec00 - 0x0000ecff (0x100) IX[B]
[41] -1 0 0x0000ff00 - 0x0000ff7f (0x80) IX[B]
[42] -1 0 0x0000af00 - 0x0000af7f (0x80) IXB
[43] 0 0 0xc00003b0 - 0xc00003bb (0xc) IS[B]
[44] 0 0 0xc00003c0 - 0xc00003df (0x20) IS[B]
(II) Setting vga for screen 0.
() NVIDIA(0): Depth 24, (–) framebuffer bpp 32
(==) NVIDIA(0): RGB weight 888
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
) NVIDIA(0): Enabling RENDER acceleration
(II) NVIDIA(0): NVIDIA GPU GeForce 7900 GT at PCI:2:0:0
(–) NVIDIA(0): VideoRAM: 262144 kBytes
(–) NVIDIA(0): VideoBIOS: 05.71.22.12.02
(II) NVIDIA(0): Detected PCI Express Link width: 16X
(–) NVIDIA(0): Interlaced video modes are supported on this GPU
(–) NVIDIA(0): Connected display device(s) on GeForce 7900 GT at PCI:2:0:0:
(–) NVIDIA(0): Samsung SyncMaster (CRT-0)
(–) NVIDIA(0): Samsung SyncMaster (CRT-0): 400.0 MHz maximum pixel clock
(II) NVIDIA(0): Assigned Display Device: CRT-0
(II) NVIDIA(0): Validated modes:
(II) NVIDIA(0): “1600x1200”
(II) NVIDIA(0): “1280x1024”
(II) NVIDIA(0): “1024x768”
(II) NVIDIA(0): “832x624”
(II) NVIDIA(0): “800x600”
(II) NVIDIA(0): “720x400”
(II) NVIDIA(0): “640x480”
(II) NVIDIA(0): Virtual screen size determined to be 1600 x 1200
(–) NVIDIA(0): DPI set to (92, 100); computed from “UseEdidDpi” X config option
(–) Depth 24 pixmap format is 32 bpp
(II) do I need RAC? No, I don’t.
(II) resource ranges after preInit:
[0] 0 0 0xde000000 - 0xdeffffff (0x1000000) MX[B]
[1] 0 0 0xb0000000 - 0xbfffffff (0x10000000) MX[B]
[2] 0 0 0xdd000000 - 0xddffffff (0x1000000) MX[B]
[3] -1 0 0xffe00000 - 0xffffffff (0x200000) MXB
[4] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[5] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[6] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[7] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[8] -1 0 0xdfffb000 - 0xdfffb0ff (0x100) MX[B]
[9] -1 0 0xdfffc000 - 0xdfffc0ff (0x100) MX[B]
[10] -1 0 0xdfff4000 - 0xdfff7fff (0x4000) MX[B]
[11] -1 0 0xdfffd000 - 0xdfffd7ff (0x800) MX[B]
[12] -1 0 0xdfffe000 - 0xdfffe0ff (0x100) MX[B]
[13] -1 0 0xdffff000 - 0xdffff7ff (0x800) MX[B]
[14] -1 0 0xd0000000 - 0xcfffffff (0x0) MX[B]O
[15] -1 0 0xde000000 - 0xdeffffff (0x1000000) MXB
[16] -1 0 0xb0000000 - 0xbfffffff (0x10000000) MXB
[17] -1 0 0xdd000000 - 0xddffffff (0x1000000) MXB
[18] 0 0 0x000a0000 - 0x000affff (0x10000) MSB
[19] 0 0 0x000b0000 - 0x000b7fff (0x8000) MSB
[20] 0 0 0x000b8000 - 0x000bffff (0x8000) MSB
[21] 0 0 0x0000af00 - 0x0000af7f (0x80) IX[B]
[22] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[23] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[24] -1 0 0x0000ee00 - 0x0000ee1f (0x20) IX[B]
[25] -1 0 0x0000ef00 - 0x0000ef1f (0x20) IX[B]
[26] -1 0 0x0000f000 - 0x0000f01f (0x20) IX[B]
[27] -1 0 0x0000f100 - 0x0000f11f (0x20) IX[B]
[28] -1 0 0x0000f200 - 0x0000f20f (0x10) IX[B]
[29] -1 0 0x0000e800 - 0x0000e8ff (0x100) IX[B]
[30] -1 0 0x0000f300 - 0x0000f30f (0x10) IX[B]
[31] -1 0 0x0000f400 - 0x0000f403 (0x4) IX[B]
[32] -1 0 0x0000f500 - 0x0000f507 (0x8) IX[B]
[33] -1 0 0x0000f600 - 0x0000f603 (0x4) IX[B]
[34] -1 0 0x0000f700 - 0x0000f707 (0x8) IX[B]
[35] -1 0 0x0000e600 - 0x0000e6ff (0x100) IX[B]
[36] -1 0 0x0000ea00 - 0x0000eaff (0x100) IX[B]
[37] -1 0 0x0000f800 - 0x0000f81f (0x20) IX[B]
[38] -1 0 0x0000f900 - 0x0000f90f (0x10) IX[B]
[39] -1 0 0x0000fa00 - 0x0000fa0f (0x10) IX[B]
[40] -1 0 0x0000fb00 - 0x0000fb0f (0x10) IX[B]
[41] -1 0 0x0000fc00 - 0x0000fc0f (0x10) IX[B]
[42] -1 0 0x0000fd00 - 0x0000fd07 (0x8) IX[B]
[43] -1 0 0x0000fe00 - 0x0000fe3f (0x40) IX[B]
[44] -1 0 0x0000ec00 - 0x0000ecff (0x100) IX[B]
[45] -1 0 0x0000ff00 - 0x0000ff7f (0x80) IX[B]
[46] -1 0 0x0000af00 - 0x0000af7f (0x80) IXB
[47] 0 0 0xc00003b0 - 0xc00003bb (0xc) IS[B]
[48] 0 0 0xc00003c0 - 0xc00003df (0x20) IS[B]
(II) NVIDIA(0): Setting mode “1600x1200”
(II) Loading extension NV-GLX
(II) NVIDIA(0): NVIDIA 3D Acceleration Architecture Initialized
(II) NVIDIA(0): Using the NVIDIA 2D acceleration architecture
(==) NVIDIA(0): Backing store disabled
(==) NVIDIA(0): Silken mouse enabled
() Option “dpms”
) NVIDIA(0): DPMS enabled
(II) Loading extension NV-CONTROL
(==) RandR enabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) Initializing built-in extension XEVIE
(II) Initializing extension GLX
error opening security policy file /etc/X11/xserver/SecurityPolicy
() Option “CoreKeyboard”
) Generic Keyboard: Core Keyboard
() Option “Protocol” “standard”
) Generic Keyboard: Protocol: standard
() Option “AutoRepeat” “500 30”
) Option “XkbRules” “xorg”
() Generic Keyboard: XkbRules: “xorg”
) Option “XkbModel” “pc104”
() Generic Keyboard: XkbModel: “pc104”
) Option “XkbLayout” “us”
() Generic Keyboard: XkbLayout: “us”
) Option “CustomKeycodes” “off”
() Generic Keyboard: CustomKeycodes disabled
) Option “Protocol” “ExplorerPS/2”
() Configured Mouse: Device: “/dev/input/mice”
) Configured Mouse: Protocol: “ExplorerPS/2”
() Option “CorePointer”
) Configured Mouse: Core Pointer
() Option “Device” “/dev/input/mice”
) Option “Emulate3Buttons” “true”
() Configured Mouse: Emulate3Buttons, Emulate3Timeout: 50
) Configured Mouse: ZAxisMapping: buttons 4, 5, 6 and 7
(**) Configured Mouse: Buttons: 11
(II) XINPUT: Adding extended input device “Configured Mouse” (type: MOUSE)
(II) XINPUT: Adding extended input device “Generic Keyboard” (type: KEYBOARD)
(II) XINPUT: Adding extended input device “NVIDIA Event Handler” (type: Other)
(II) Configured Mouse: ps2EnableDataReporting: succeeded
Could not init font path element /usr/share/fonts/truetype, removing from list!
Could not init font path element /usr/share/fonts/X11/TTF/, removing from list!
Could not init font path element /usr/share/fonts/X11/OTF, removing from list!
Could not init font path element /usr/share/fonts/X11/Type1/, removing from list!
Could not init font path element /usr/share/fonts/X11/CID/, removing from list[/code]
Right then… here is messages:
[i]$[/i]:/var/log# cat messages Dec 3 06:47:14 joe01 syslogd 1.4.1#18: restart. Dec 3 07:02:40 joe01 -- MARK -- Dec 3 07:22:41 joe01 -- MARK -- Dec 3 07:42:41 joe01 -- MARK -- Dec 3 08:02:41 joe01 -- MARK -- Dec 3 08:22:41 joe01 -- MARK -- Dec 3 08:42:41 joe01 -- MARK -- Dec 3 09:02:41 joe01 -- MARK -- Dec 3 09:22:41 joe01 -- MARK -- Dec 3 09:42:41 joe01 -- MARK -- Dec 3 10:02:41 joe01 -- MARK -- Dec 3 10:22:41 joe01 -- MARK -- Dec 3 10:42:41 joe01 -- MARK -- Dec 3 11:02:41 joe01 -- MARK -- Dec 3 11:22:41 joe01 -- MARK -- Dec 3 11:42:42 joe01 -- MARK -- Dec 3 12:02:42 joe01 -- MARK -- Dec 3 12:22:42 joe01 -- MARK -- Dec 3 12:42:42 joe01 -- MARK -- Dec 3 13:02:42 joe01 -- MARK -- Dec 3 13:22:42 joe01 -- MARK -- Dec 3 13:42:42 joe01 -- MARK -- Dec 3 14:02:42 joe01 -- MARK -- Dec 3 14:22:42 joe01 -- MARK -- Dec 3 14:42:42 joe01 -- MARK -- Dec 3 15:02:42 joe01 -- MARK -- Dec 3 15:22:42 joe01 -- MARK -- Dec 3 15:42:42 joe01 -- MARK -- Dec 3 16:02:43 joe01 -- MARK -- Dec 3 16:22:43 joe01 -- MARK -- Dec 3 16:42:43 joe01 -- MARK -- Dec 3 17:02:43 joe01 -- MARK -- Dec 3 17:22:43 joe01 -- MARK -- Dec 3 17:42:43 joe01 -- MARK -- Dec 3 18:02:43 joe01 -- MARK -- Dec 3 18:22:43 joe01 -- MARK -- Dec 3 18:42:43 joe01 -- MARK -- Dec 3 19:02:43 joe01 -- MARK -- Dec 3 19:22:43 joe01 -- MARK -- Dec 3 19:42:43 joe01 -- MARK -- Dec 3 20:02:43 joe01 -- MARK -- Dec 3 20:22:43 joe01 -- MARK -- Dec 3 20:42:44 joe01 -- MARK -- Dec 3 21:02:44 joe01 -- MARK -- Dec 3 21:09:05 joe01 kernel: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1 Dec 3 21:09:05 joe01 kernel: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready Dec 3 21:12:24 joe01 gconfd (joe-8002): starting (version 2.16.0), pid 8002 user 'joe' Dec 3 21:12:24 joe01 gconfd (joe-8002): Resolved address "xml:readonly:/etc/gconf/gconf.xml.mandatory" to a read-only configuration source at position 0 Dec 3 21:12:24 joe01 gconfd (joe-8002): Resolved address "xml:readwrite:/home/joe/.gconf" to a writable configuration source at position 1 Dec 3 21:12:24 joe01 gconfd (joe-8002): Resolved address "xml:readonly:/etc/gconf/gconf.xml.defaults" to a read-only configuration source at position 2 Dec 3 21:12:24 joe01 gconfd (joe-8002): Resolved address "xml:readonly:/var/lib/gconf/debian.defaults" to a read-only configuration source at position 3 Dec 3 21:12:24 joe01 gconfd (joe-8002): Resolved address "xml:readonly:/var/lib/gconf/defaults" to a read-only configuration source at position 4 Dec 3 21:12:54 joe01 gconfd (joe-8002): GConf server is not in use, shutting down. Dec 3 21:12:54 joe01 gconfd (joe-8002): Exiting Dec 3 21:13:03 joe01 kernel: eth0: link down Dec 3 21:13:13 joe01 kernel: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1 Dec 3 21:15:11 joe01 gconfd (joe-8035): starting (version 2.16.0), pid 8035 user 'joe' Dec 3 21:15:11 joe01 gconfd (joe-8035): Resolved address "xml:readonly:/etc/gconf/gconf.xml.mandatory" to a read-only configuration source at position 0 Dec 3 21:15:11 joe01 gconfd (joe-8035): Resolved address "xml:readwrite:/home/joe/.gconf" to a writable configuration source at position 1 Dec 3 21:15:11 joe01 gconfd (joe-8035): Resolved address "xml:readonly:/etc/gconf/gconf.xml.defaults" to a read-only configuration source at position 2 Dec 3 21:15:11 joe01 gconfd (joe-8035): Resolved address "xml:readonly:/var/lib/gconf/debian.defaults" to a read-only configuration source at position 3 Dec 3 21:15:11 joe01 gconfd (joe-8035): Resolved address "xml:readonly:/var/lib/gconf/defaults" to a read-only configuration source at position 4 Dec 3 21:15:41 joe01 gconfd (joe-8035): GConf server is not in use, shutting down. Dec 3 21:15:41 joe01 gconfd (joe-8035): Exiting Dec 3 21:16:39 joe01 gconfd (joe-8047): starting (version 2.16.0), pid 8047 user 'joe' Dec 3 21:16:39 joe01 gconfd (joe-8047): Resolved address "xml:readonly:/etc/gconf/gconf.xml.mandatory" to a read-only configuration source at position 0 Dec 3 21:16:39 joe01 gconfd (joe-8047): Resolved address "xml:readwrite:/home/joe/.gconf" to a writable configuration source at position 1 Dec 3 21:16:39 joe01 gconfd (joe-8047): Resolved address "xml:readonly:/etc/gconf/gconf.xml.defaults" to a read-only configuration source at position 2 Dec 3 21:16:39 joe01 gconfd (joe-8047): Resolved address "xml:readonly:/var/lib/gconf/debian.defaults" to a read-only configuration source at position 3 Dec 3 21:16:39 joe01 gconfd (joe-8047): Resolved address "xml:readonly:/var/lib/gconf/defaults" to a read-only configuration source at position 4 Dec 3 21:17:39 joe01 gconfd (joe-8047): GConf server is not in use, shutting down. Dec 3 21:17:39 joe01 gconfd (joe-8047): Exiting Dec 3 21:17:45 joe01 shutdown[8088]: shutting down for system reboot Dec 3 21:17:51 joe01 kernel: Kernel logging (proc) stopped. Dec 3 21:17:51 joe01 kernel: Kernel log daemon terminating. Dec 3 21:17:52 joe01 exiting on signal 15 Dec 3 21:19:05 joe01 syslogd 1.4.1#18: restart. Dec 3 21:19:05 joe01 kernel: klogd 1.4.1#18, log source = /proc/kmsg started. Dec 3 21:19:05 joe01 kernel: ramework v1.0.0 initialized Dec 3 21:19:05 joe01 kernel: SELinux: Disabled at boot. Dec 3 21:19:05 joe01 kernel: Capability LSM initialized Dec 3 21:19:05 joe01 kernel: Mount-cache hash table entries: 512 Dec 3 21:19:05 joe01 kernel: CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line) Dec 3 21:19:05 joe01 kernel: CPU: L2 Cache: 512K (64 bytes/line) Dec 3 21:19:05 joe01 kernel: CPU: AMD Athlon(tm) 64 Processor 3500+ stepping 00 Dec 3 21:19:05 joe01 kernel: Checking 'hlt' instruction... OK. Dec 3 21:19:05 joe01 kernel: SMP alternatives: switching to UP code Dec 3 21:19:05 joe01 kernel: Freeing SMP alternatives: 0k freed Dec 3 21:19:05 joe01 kernel: ENABLING IO-APIC IRQs Dec 3 21:19:05 joe01 kernel: ..TIMER: vector=0x31 apic1=0 pin1=2 apic2=0 pin2=0 Dec 3 21:19:05 joe01 kernel: checking if image is initramfs... it is Dec 3 21:19:05 joe01 kernel: Freeing initrd memory: 4169k freed Dec 3 21:19:05 joe01 kernel: NET: Registered protocol family 16 Dec 3 21:19:05 joe01 kernel: EISA bus registered Dec 3 21:19:05 joe01 kernel: ACPI: bus type pci registered Dec 3 21:19:05 joe01 kernel: PCI: Using MMCONFIG Dec 3 21:19:05 joe01 kernel: PCI: No mmconfig possible on 0:18 Dec 3 21:19:05 joe01 kernel: Setting up standard PCI resources Dec 3 21:19:05 joe01 kernel: ACPI: Subsystem revision 20060127 Dec 3 21:19:05 joe01 kernel: ACPI: Interpreter enabled Dec 3 21:19:05 joe01 kernel: ACPI: Using IOAPIC for interrupt routing Dec 3 21:19:05 joe01 kernel: ACPI: PCI Root Bridge [PCI0] (0000:00) Dec 3 21:19:05 joe01 kernel: PCI: Quirk-MSI-K8T Soundcard On Dec 3 21:19:05 joe01 kernel: PCI: Unexpected Value in PCI-Register: no Change! Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 6 7 10 11 12) *5 Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 6 7 *10 11 12) Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 6 7 10 *11 12) Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 6 7 10 11 12) *0, disabled. Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 6 7 10 *11 12) Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 6 7 10 11 12) *5 Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt Link [LNK0] (IRQs 3 4 6 7 10 *11 12) Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 6 7 *10 11 12) Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt Link [ALKA] (IRQs *20) Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt Link [ALKB] (IRQs *21) Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt Link [ALKC] (IRQs *22), disabled. Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt Link [ALKD] (IRQs *23), disabled. Dec 3 21:19:05 joe01 kernel: Linux Plug and Play Support v0.97 (c) Adam Belay Dec 3 21:19:05 joe01 kernel: pnp: PnP ACPI init Dec 3 21:19:05 joe01 kernel: pnp: PnP ACPI: found 14 devices Dec 3 21:19:05 joe01 kernel: PnPBIOS: Disabled by ACPI PNP Dec 3 21:19:05 joe01 kernel: PCI: Using ACPI for IRQ routing Dec 3 21:19:05 joe01 kernel: PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report Dec 3 21:19:05 joe01 kernel: pnp: 00:01: ioport range 0x4000-0x407f could not be reserved Dec 3 21:19:05 joe01 kernel: pnp: 00:01: ioport range 0x5000-0x500f has been reserved Dec 3 21:19:05 joe01 kernel: PCI: Bridge: 0000:00:01.0 Dec 3 21:19:05 joe01 kernel: IO window: b000-bfff Dec 3 21:19:05 joe01 kernel: MEM window: dfb00000-dfbfffff Dec 3 21:19:05 joe01 kernel: PREFETCH window: dfa00000-dfafffff Dec 3 21:19:05 joe01 kernel: PCI: Bridge: 0000:00:02.0 Dec 3 21:19:05 joe01 kernel: IO window: a000-afff Dec 3 21:19:05 joe01 kernel: MEM window: dd000000-deffffff Dec 3 21:19:05 joe01 kernel: PREFETCH window: b0000000-cfffffff Dec 3 21:19:05 joe01 kernel: PCI: Bridge: 0000:00:03.0 Dec 3 21:19:05 joe01 kernel: IO window: 9000-9fff Dec 3 21:19:05 joe01 kernel: MEM window: disabled. Dec 3 21:19:05 joe01 kernel: PREFETCH window: df800000-df8fffff Dec 3 21:19:05 joe01 kernel: PCI: Bridge: 0000:00:03.1 Dec 3 21:19:05 joe01 kernel: IO window: 8000-8fff Dec 3 21:19:05 joe01 kernel: MEM window: disabled. Dec 3 21:19:05 joe01 kernel: PREFETCH window: df600000-df6fffff Dec 3 21:19:05 joe01 kernel: PCI: Bridge: 0000:00:03.2 Dec 3 21:19:05 joe01 kernel: IO window: d000-dfff Dec 3 21:19:05 joe01 kernel: MEM window: disabled. Dec 3 21:19:05 joe01 kernel: PREFETCH window: dfe00000-dfefffff Dec 3 21:19:05 joe01 kernel: PCI: Bridge: 0000:00:03.3 Dec 3 21:19:05 joe01 kernel: IO window: c000-cfff Dec 3 21:19:05 joe01 kernel: MEM window: disabled. Dec 3 21:19:05 joe01 kernel: PREFETCH window: dfc00000-dfcfffff Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt 0000:00:02.0[A] -> GSI 27 (level, low) -> IRQ 169 Dec 3 21:19:05 joe01 kernel: PCI: Enabling device 0000:00:03.0 (0000 -> 0003) Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt 0000:00:03.0[A] -> GSI 31 (level, low) -> IRQ 177 Dec 3 21:19:05 joe01 kernel: PCI: Enabling device 0000:00:03.1 (0000 -> 0003) Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt 0000:00:03.1[B] -> GSI 35 (level, low) -> IRQ 185 Dec 3 21:19:05 joe01 kernel: PCI: Enabling device 0000:00:03.2 (0000 -> 0003) Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt 0000:00:03.2[C] -> GSI 39 (level, low) -> IRQ 193 Dec 3 21:19:05 joe01 kernel: PCI: Enabling device 0000:00:03.3 (0000 -> 0003) Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt 0000:00:03.3[D] -> GSI 43 (level, low) -> IRQ 201 Dec 3 21:19:05 joe01 kernel: NET: Registered protocol family 2 Dec 3 21:19:05 joe01 kernel: IP route cache hash table entries: 32768 (order: 5, 131072 bytes) Dec 3 21:19:05 joe01 kernel: TCP established hash table entries: 131072 (order: 7, 524288 bytes) Dec 3 21:19:05 joe01 kernel: TCP bind hash table entries: 65536 (order: 6, 262144 bytes) Dec 3 21:19:05 joe01 kernel: TCP: Hash tables configured (established 131072 bind 65536) Dec 3 21:19:05 joe01 kernel: TCP reno registered Dec 3 21:19:05 joe01 kernel: audit: initializing netlink socket (disabled) Dec 3 21:19:05 joe01 kernel: audit(1165209503.964:1): initialized Dec 3 21:19:05 joe01 kernel: VFS: Disk quotas dquot_6.5.1 Dec 3 21:19:05 joe01 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) Dec 3 21:19:05 joe01 kernel: Initializing Cryptographic API Dec 3 21:19:05 joe01 kernel: io scheduler noop registered Dec 3 21:19:05 joe01 kernel: io scheduler anticipatory registered (default) Dec 3 21:19:05 joe01 kernel: io scheduler deadline registered Dec 3 21:19:05 joe01 kernel: io scheduler cfq registered Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt 0000:00:02.0[A] -> GSI 27 (level, low) -> IRQ 169 Dec 3 21:19:05 joe01 kernel: assign_interrupt_mode Found MSI capability Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt 0000:00:03.0[A] -> GSI 31 (level, low) -> IRQ 177 Dec 3 21:19:05 joe01 kernel: assign_interrupt_mode Found MSI capability Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt 0000:00:03.1[B] -> GSI 35 (level, low) -> IRQ 185 Dec 3 21:19:05 joe01 kernel: assign_interrupt_mode Found MSI capability Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt 0000:00:03.2[C] -> GSI 39 (level, low) -> IRQ 193 Dec 3 21:19:05 joe01 kernel: assign_interrupt_mode Found MSI capability Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt 0000:00:03.3[D] -> GSI 43 (level, low) -> IRQ 201 Dec 3 21:19:05 joe01 kernel: assign_interrupt_mode Found MSI capability Dec 3 21:19:05 joe01 kernel: isapnp: Scanning for PnP cards... Dec 3 21:19:05 joe01 kernel: isapnp: No Plug & Play device found Dec 3 21:19:05 joe01 kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled Dec 3 21:19:05 joe01 kernel: serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A Dec 3 21:19:05 joe01 kernel: RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize Dec 3 21:19:05 joe01 kernel: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12 Dec 3 21:19:05 joe01 kernel: serio: i8042 AUX port at 0x60,0x64 irq 12 Dec 3 21:19:05 joe01 kernel: serio: i8042 KBD port at 0x60,0x64 irq 1 Dec 3 21:19:05 joe01 kernel: EISA: Probing bus 0 at eisa.0 Dec 3 21:19:05 joe01 kernel: Cannot allocate resource for EISA slot 4 Dec 3 21:19:05 joe01 kernel: Cannot allocate resource for EISA slot 5 Dec 3 21:19:05 joe01 kernel: Cannot allocate resource for EISA slot 8 Dec 3 21:19:05 joe01 kernel: EISA: Detected 0 cards. Dec 3 21:19:05 joe01 kernel: TCP bic registered Dec 3 21:19:05 joe01 kernel: NET: Registered protocol family 1 Dec 3 21:19:05 joe01 kernel: NET: Registered protocol family 17 Dec 3 21:19:05 joe01 kernel: NET: Registered protocol family 8 Dec 3 21:19:05 joe01 kernel: NET: Registered protocol family 20 Dec 3 21:19:05 joe01 kernel: Using IPI Shortcut mode Dec 3 21:19:05 joe01 kernel: ACPI wakeup devices: Dec 3 21:19:05 joe01 kernel: PCI0 USB0 USB1 USB2 USB3 USB4 USB5 USB6 USB7 AC97 MC97 PEXG PEX0 PEX1 PEX2 PEX3 UAR1 Dec 3 21:19:05 joe01 kernel: ACPI: (supports S0 S3 S4 S5) Dec 3 21:19:05 joe01 kernel: Freeing unused kernel memory: 252k freed Dec 3 21:19:05 joe01 kernel: input: AT Translated Set 2 keyboard as /class/input/input0 Dec 3 21:19:05 joe01 kernel: usbcore: registered new driver usbfs Dec 3 21:19:05 joe01 kernel: usbcore: registered new driver hub Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt Link [ALKB] enabled at IRQ 21 Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt 0000:00:10.4[C] -> Link [ALKB] -> GSI 21 (level, low) -> IRQ 66 Dec 3 21:19:05 joe01 kernel: ehci_hcd 0000:00:10.4: EHCI Host Controller Dec 3 21:19:05 joe01 kernel: ehci_hcd 0000:00:10.4: new USB bus registered, assigned bus number 1 Dec 3 21:19:05 joe01 kernel: ehci_hcd 0000:00:10.4: irq 66, io mem 0xdfffb000 Dec 3 21:19:05 joe01 kernel: ehci_hcd 0000:00:10.4: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004 Dec 3 21:19:05 joe01 kernel: usb usb1: configuration #1 chosen from 1 choice Dec 3 21:19:05 joe01 kernel: hub 1-0:1.0: USB hub found Dec 3 21:19:05 joe01 kernel: hub 1-0:1.0: 8 ports detected Dec 3 21:19:05 joe01 kernel: USB Universal Host Controller Interface driver v3.0 Dec 3 21:19:05 joe01 kernel: Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2 Dec 3 21:19:05 joe01 kernel: ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx Dec 3 21:19:05 joe01 kernel: SCSI subsystem initialized Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt 0000:00:10.0[A] -> Link [ALKB] -> GSI 21 (level, low) -> IRQ 66 Dec 3 21:19:05 joe01 kernel: PCI: VIA IRQ fixup for 0000:00:10.0, from 5 to 2 Dec 3 21:19:05 joe01 kernel: uhci_hcd 0000:00:10.0: UHCI Host Controller Dec 3 21:19:05 joe01 kernel: uhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 2 Dec 3 21:19:05 joe01 kernel: uhci_hcd 0000:00:10.0: irq 66, io base 0x0000f100 Dec 3 21:19:05 joe01 kernel: usb usb2: configuration #1 chosen from 1 choice Dec 3 21:19:05 joe01 kernel: hub 2-0:1.0: USB hub found Dec 3 21:19:05 joe01 kernel: hub 2-0:1.0: 2 ports detected Dec 3 21:19:05 joe01 kernel: 8139too Fast Ethernet driver 0.9.27 Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt 0000:00:10.1[A] -> Link [ALKB] -> GSI 21 (level, low) -> IRQ 66 Dec 3 21:19:05 joe01 kernel: PCI: VIA IRQ fixup for 0000:00:10.1, from 5 to 2 Dec 3 21:19:05 joe01 kernel: uhci_hcd 0000:00:10.1: UHCI Host Controller Dec 3 21:19:05 joe01 kernel: uhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 3 Dec 3 21:19:05 joe01 kernel: uhci_hcd 0000:00:10.1: irq 66, io base 0x0000f000 Dec 3 21:19:05 joe01 kernel: usb usb3: configuration #1 chosen from 1 choice Dec 3 21:19:05 joe01 kernel: hub 3-0:1.0: USB hub found Dec 3 21:19:05 joe01 kernel: hub 3-0:1.0: 2 ports detected Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt 0000:00:10.2[B] -> Link [ALKB] -> GSI 21 (level, low) -> IRQ 66 Dec 3 21:19:05 joe01 kernel: PCI: VIA IRQ fixup for 0000:00:10.2, from 10 to 2 Dec 3 21:19:05 joe01 kernel: uhci_hcd 0000:00:10.2: UHCI Host Controller Dec 3 21:19:05 joe01 kernel: uhci_hcd 0000:00:10.2: new USB bus registered, assigned bus number 4 Dec 3 21:19:05 joe01 kernel: uhci_hcd 0000:00:10.2: irq 66, io base 0x0000ef00 Dec 3 21:19:05 joe01 kernel: usb usb4: configuration #1 chosen from 1 choice Dec 3 21:19:05 joe01 kernel: hub 4-0:1.0: USB hub found Dec 3 21:19:05 joe01 kernel: hub 4-0:1.0: 2 ports detected Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt 0000:00:10.3[B] -> Link [ALKB] -> GSI 21 (level, low) -> IRQ 66 Dec 3 21:19:05 joe01 kernel: PCI: VIA IRQ fixup for 0000:00:10.3, from 10 to 2 Dec 3 21:19:05 joe01 kernel: uhci_hcd 0000:00:10.3: UHCI Host Controller Dec 3 21:19:05 joe01 kernel: uhci_hcd 0000:00:10.3: new USB bus registered, assigned bus number 5 Dec 3 21:19:05 joe01 kernel: uhci_hcd 0000:00:10.3: irq 66, io base 0x0000ee00 Dec 3 21:19:05 joe01 kernel: usb usb5: configuration #1 chosen from 1 choice Dec 3 21:19:05 joe01 kernel: hub 5-0:1.0: USB hub found Dec 3 21:19:05 joe01 kernel: hub 5-0:1.0: 2 ports detected Dec 3 21:19:05 joe01 kernel: VP_IDE: IDE controller at PCI slot 0000:00:0f.1 Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt Link [ALKA] enabled at IRQ 20 Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt 0000:00:0f.1[A] -> Link [ALKA] -> GSI 20 (level, low) -> IRQ 74 Dec 3 21:19:05 joe01 kernel: PCI: VIA IRQ fixup for 0000:00:0f.1, from 255 to 10 Dec 3 21:19:05 joe01 kernel: VP_IDE: chipset revision 6 Dec 3 21:19:05 joe01 kernel: VP_IDE: not 100%% native mode: will probe irqs later Dec 3 21:19:05 joe01 kernel: VP_IDE: VIA vt8237 (rev 00) IDE UDMA133 controller on pci0000:00:0f.1 Dec 3 21:19:05 joe01 kernel: ide0: BM-DMA at 0xf200-0xf207, BIOS settings: hda:DMA, hdb:DMA Dec 3 21:19:05 joe01 kernel: ide1: BM-DMA at 0xf208-0xf20f, BIOS settings: hdc:pio, hdd:pio Dec 3 21:19:05 joe01 kernel: hda: LITE-ON DVDRW SOHW-1693S, ATAPI CD/DVD-ROM drive Dec 3 21:19:05 joe01 kernel: hdb: LITE-ON CD-ROM LTN-529S, ATAPI CD/DVD-ROM drive Dec 3 21:19:05 joe01 kernel: ide0 at 0x1f0-0x1f7,0x3f6 on irq 14 Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt 0000:00:07.0[A] -> GSI 21 (level, low) -> IRQ 66 Dec 3 21:19:05 joe01 kernel: ohci1394: fw-host0: OHCI-1394 1.0 (PCI): IRQ=[66] MMIO=[dffff000-dffff7ff] Max Packet=[2048] IR/IT contexts=[4/8] Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt 0000:00:09.2[B] -> GSI 18 (level, low) -> IRQ 82 Dec 3 21:19:05 joe01 kernel: ohci1394: fw-host1: OHCI-1394 1.1 (PCI): IRQ=[82] MMIO=[dfffd000-dfffd7ff] Max Packet=[2048] IR/IT contexts=[4/8] Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt 0000:00:0c.0[A] -> GSI 20 (level, low) -> IRQ 74 Dec 3 21:19:05 joe01 kernel: sata_via 0000:00:0c.0: routed to hard irq line 11 Dec 3 21:19:05 joe01 kernel: ata1: SATA max UDMA/133 cmd 0xFC00 ctl 0xFC0A bmdma 0xF800 irq 74 Dec 3 21:19:05 joe01 kernel: ata2: SATA max UDMA/133 cmd 0xFB00 ctl 0xFB0A bmdma 0xF808 irq 74 Dec 3 21:19:05 joe01 kernel: ata1: SATA link down (SStatus 0) Dec 3 21:19:05 joe01 kernel: scsi0 : sata_via Dec 3 21:19:05 joe01 kernel: ata2: SATA link down (SStatus 0) Dec 3 21:19:05 joe01 kernel: scsi1 : sata_via Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt 0000:00:0f.0[B] -> Link [ALKA] -> GSI 20 (level, low) -> IRQ 74 Dec 3 21:19:05 joe01 kernel: sata_via 0000:00:0f.0: routed to hard irq line 10 Dec 3 21:19:05 joe01 kernel: ata3: SATA max UDMA/133 cmd 0xF700 ctl 0xF602 bmdma 0xF300 irq 74 Dec 3 21:19:05 joe01 kernel: ata4: SATA max UDMA/133 cmd 0xF500 ctl 0xF402 bmdma 0xF308 irq 74 Dec 3 21:19:05 joe01 kernel: ata3: SATA link down (SStatus 0) Dec 3 21:19:05 joe01 kernel: scsi2 : sata_via Dec 3 21:19:05 joe01 kernel: ata4: SATA link up 1.5 Gbps (SStatus 113) Dec 3 21:19:05 joe01 kernel: ata4: dev 0 ATA-6, max UDMA/133, 390721968 sectors: LBA48 Dec 3 21:19:05 joe01 kernel: ata4: dev 0 configured for UDMA/133 Dec 3 21:19:05 joe01 kernel: scsi3 : sata_via Dec 3 21:19:05 joe01 kernel: Vendor: ATA Model: ST3200822AS Rev: 3.01 Dec 3 21:19:05 joe01 kernel: Type: Direct-Access ANSI SCSI revision: 05 Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt 0000:00:08.0[A] -> GSI 16 (level, low) -> IRQ 90 Dec 3 21:19:05 joe01 kernel: eth0: RealTek RTL8139 at 0xec00, 00:40:f4:51:8c:ba, IRQ 90 Dec 3 21:19:05 joe01 kernel: 8139cp: 10/100 PCI Ethernet driver v1.2 (Mar 22, 2004) Dec 3 21:19:05 joe01 kernel: hda: ATAPI 48X DVD-ROM DVD-R CD-R/RW drive, 2048kB Cache Dec 3 21:19:05 joe01 kernel: Uniform CD-ROM driver Revision: 3.20 Dec 3 21:19:05 joe01 kernel: hdb: ATAPI 52X CD-ROM drive, 128kB Cache, UDMA(33) Dec 3 21:19:05 joe01 kernel: SCSI device sda: 390721968 512-byte hdwr sectors (200050 MB) Dec 3 21:19:05 joe01 kernel: sda: Write Protect is off Dec 3 21:19:05 joe01 kernel: SCSI device sda: drive cache: write back Dec 3 21:19:05 joe01 kernel: SCSI device sda: 390721968 512-byte hdwr sectors (200050 MB) Dec 3 21:19:05 joe01 kernel: sda: Write Protect is off Dec 3 21:19:05 joe01 kernel: SCSI device sda: drive cache: write back Dec 3 21:19:05 joe01 kernel: sda: sda1 sda2 sda3 Dec 3 21:19:05 joe01 kernel: sd 3:0:0:0: Attached scsi disk sda Dec 3 21:19:05 joe01 kernel: Attempting manual resume Dec 3 21:19:05 joe01 kernel: ReiserFS: sda2: found reiserfs format "3.6" with standard journal Dec 3 21:19:05 joe01 kernel: ReiserFS: sda2: using ordered data mode Dec 3 21:19:05 joe01 kernel: ReiserFS: sda2: journal params: device sda2, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30 Dec 3 21:19:05 joe01 kernel: ReiserFS: sda2: checking transaction log (sda2) Dec 3 21:19:05 joe01 kernel: ReiserFS: sda2: Using r5 hash to sort names Dec 3 21:19:05 joe01 kernel: input: PC Speaker as /class/input/input1 Dec 3 21:19:05 joe01 kernel: eth1394: eth1: IEEE-1394 IPv4 over 1394 Ethernet (fw-host0) Dec 3 21:19:05 joe01 kernel: eth1394: eth2: IEEE-1394 IPv4 over 1394 Ethernet (fw-host1) Dec 3 21:19:05 joe01 kernel: 00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A Dec 3 21:19:05 joe01 kernel: pci_hotplug: PCI Hot Plug PCI Core version: 0.5 Dec 3 21:19:05 joe01 kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4 Dec 3 21:19:05 joe01 kernel: parport: PnPBIOS parport detected. Dec 3 21:19:05 joe01 kernel: parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE] Dec 3 21:19:05 joe01 kernel: Real Time Clock Driver v1.12ac Dec 3 21:19:05 joe01 kernel: Linux agpgart interface v0.101 (c) Dave Jones Dec 3 21:19:05 joe01 kernel: agpgart: Detected AGP bridge 0 Dec 3 21:19:05 joe01 kernel: agpgart: AGP aperture is 128M @ 0xd0000000 Dec 3 21:19:05 joe01 kernel: gameport: EMU10K1 is pci0000:00:09.1/gameport0, io 0xfd00, speed 1217kHz Dec 3 21:19:05 joe01 kernel: Floppy drive(s): fd0 is 1.44M Dec 3 21:19:05 joe01 kernel: FDC 0 is a post-1991 82077 Dec 3 21:19:05 joe01 kernel: input: PS2++ Logitech MX Mouse as /class/input/input2 Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt 0000:00:09.0[A] -> GSI 17 (level, low) -> IRQ 98 Dec 3 21:19:05 joe01 kernel: Installing spdif_bug patch: Audigy 2 ZS [SB0350] Dec 3 21:19:05 joe01 kernel: mice: PS/2 mouse device common for all mice Dec 3 21:19:05 joe01 kernel: ts: Compaq touchscreen protocol output Dec 3 21:19:05 joe01 kernel: Adding 530104k swap on /dev/sda1. Priority:-1 extents:1 across:530104k Dec 3 21:19:05 joe01 kernel: loop: loaded (max 8 devices) Dec 3 21:19:05 joe01 kernel: ieee1394: sbp2: Driver forced to serialize I/O (serialize_io=1) Dec 3 21:19:05 joe01 kernel: ieee1394: sbp2: Try serialize_io=0 for better performance Dec 3 21:19:05 joe01 kernel: nvidia: module license 'NVIDIA' taints kernel. Dec 3 21:19:05 joe01 kernel: ACPI: PCI Interrupt 0000:02:00.0[A] -> GSI 24 (level, low) -> IRQ 106 Dec 3 21:19:05 joe01 kernel: NVRM: loading NVIDIA Linux x86 Kernel Module 1.0-9629 Wed Nov 1 19:30:07 PST 2006 Dec 3 21:19:05 joe01 kernel: device-mapper: 4.6.0-ioctl (2006-02-17) initialised: [email protected] Dec 3 21:19:05 joe01 kernel: ReiserFS: sda3: found reiserfs format "3.6" with standard journal Dec 3 21:19:05 joe01 kernel: ReiserFS: sda3: using ordered data mode Dec 3 21:19:05 joe01 kernel: ReiserFS: sda3: journal params: device sda3, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30 Dec 3 21:19:05 joe01 kernel: ReiserFS: sda3: checking transaction log (sda3) Dec 3 21:19:05 joe01 kernel: ReiserFS: sda3: Using r5 hash to sort names Dec 3 21:19:05 joe01 kernel: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1 Dec 3 21:19:05 joe01 kernel: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1 Dec 3 21:19:05 joe01 kernel: ACPI: Power Button (FF) [PWRF] Dec 3 21:19:05 joe01 kernel: ACPI: Power Button (CM) [PWRB] Dec 3 21:19:05 joe01 kernel: lp0: using parport0 (interrupt-driven). Dec 3 21:19:05 joe01 kernel: ppdev: user-space parallel port driver Dec 3 21:19:10 joe01 kernel: NET: Registered protocol family 10 Dec 3 21:19:10 joe01 kernel: lo: Disabled Privacy Extensions Dec 3 21:19:10 joe01 kernel: IPv6 over IPv4 tunneling driver Dec 3 21:19:10 joe01 lpd[4643]: restarted Dec 3 21:24:29 joe01 kernel: ACPI: PCI Interrupt 0000:02:00.0[A] -> GSI 24 (level, low) -> IRQ 106 Dec 3 21:24:29 joe01 kernel: NVRM: loading NVIDIA Linux x86 Kernel Module 1.0-9629 Wed Nov 1 19:30:07 PST 2006 Dec 3 21:26:30 joe01 kernel: ACPI: PCI Interrupt 0000:02:00.0[A] -> GSI 24 (level, low) -> IRQ 106 Dec 3 21:26:30 joe01 kernel: NVRM: loading NVIDIA Linux x86 Kernel Module 1.0-9629 Wed Nov 1 19:30:07 PST 2006 Dec 3 21:27:52 joe01 gconfd (joe-6035): starting (version 2.16.0), pid 6035 user 'joe' Dec 3 21:27:52 joe01 gconfd (joe-6035): Resolved address "xml:readonly:/etc/gconf/gconf.xml.mandatory" to a read-only configuration source at position 0 Dec 3 21:27:52 joe01 gconfd (joe-6035): Resolved address "xml:readwrite:/home/joe/.gconf" to a writable configuration source at position 1 Dec 3 21:27:52 joe01 gconfd (joe-6035): Resolved address "xml:readonly:/etc/gconf/gconf.xml.defaults" to a read-only configuration source at position 2 Dec 3 21:27:52 joe01 gconfd (joe-6035): Resolved address "xml:readonly:/var/lib/gconf/debian.defaults" to a read-only configuration source at position 3 Dec 3 21:27:52 joe01 gconfd (joe-6035): Resolved address "xml:readonly:/var/lib/gconf/defaults" to a read-only configuration source at position 4
Let me know if that helps your evaluation or if you need more information. Thanks AT.
It may be a problem between that older driver version and the latest build of X.org, I don’t know. Try doing a dist-upgrade, then install the 9xxx series driver and see if it helps.[ot]BTW, next time you post logs that long, please attach them to the post, don’t just paste them in with [code] tags… it’s hard to read that way. :([/ot]
So after a couple of hours talking with AT on gaim, he managed to help me find a few nvidia scripts in /etc/rc3.d/ that I have no idea how they got there, that were trying to install 8774 drivers every time i rebooted. That’s no good, obviously… so I had to kdesu ksysv and disable anything nvidia*. Once I had saved and exited, I went and reinstalled the nvidia 9629 drivers for good measure and rebooted. For the first time in a while, I savored my sweet victory. Anyway, I thought I would post accomplishment in hopes that it may help another person.
To summarize, just disable all NVidia-related scripts in all runlevels if you want to build the drivers yourself. Otherwise, the auto-scripts will break your handiwork.
