XFX 9800GTX+ running problems
Hi
I recently bought myself a new XFX9800GTX+ GPU for my PC to replace my old Gainward 8600GT, but after fitting the new card in my PC i found that I cant run any of the games on any higher settings than my 8600GT and in some cases i couldnt even run them at the same settings as my 8600GT would without the games lagging and crashing. I have made sure that I have the lastest drivers from Nvidia aswell as the lastest BIOS but still doesnt seem to help
My current System is:
AMD 3.0Ghz Dual Core
2Gb RAM
ASUS M2N4-SLI Motherboard
500Gb Hard Drive
XFX 9800GTX+
600W OCZ Gaming PSU
Somebody please help me!!
Jamie
uninstall ATI drivers etc and then install the drivers again. (after uninstall do a restart)
Ive tried that and it still doesnt the same thing I also tried my old graphics card back in my PC again and it works fine but when i switched back to the 9800 the problems return.
Jamie
ok sounds like you have updated the drives etc one thing to try is a clean install of the OS on another hard drive if possible, this will eliminate any corrupt settings/files etc.
Or graphics card is damaged and needs replacing!
I havent formatted my PC but i have tried placing my old 8600GT back in after the 9800GTX had been in there and all of th problems that i had stop and the computer functions as it used to before i originally bought the 9800GTX. Would that indicate that there isnt a corrupt file or might it be something to do with the files with the 9800GtX
Jamie
