xgp slot is the problem??
i recently bought a 64 bit mother board with pci express and a xgp slot. i dnt have money to buy a pci express card right away so i am using a nvidia 6200 agp card on the xgp slot. games are working fine but i cant watch any videos on my computer. when i try it jus stalls my computer and prcessor usage goes to 100%. how can i fix this? i knw its the drivers for the card and i ahve the latest ones. help!!!
It likely is the XGP slot,
check this out: http://www.biostar-usa.com/knowledgespec.asp?faqid=99962
It looks like older cards are the target components for this slot unfortunatly, this could be what is causing the odd experience. I can’t say it makes any sense but keep that in mind. You may want to concider RMAing your 6200 for a PCIe version, the price varies very little.
[QUOTE=Exfoliate]
well actually last night i figured out the problem and its the direct draw. when i disable that i am able to watch the videos however i cant play games. and when i enable it i can play my games but cant watch videos.so it is the xgp slot i guess..thanks anyways
No prob man. Well I dont’ know about you but I’d hate to keep messing with that, I’d just RMA it and get a PCIe version.
