I do not know if I am asking this question wrong. I need into my computer. I have 5 files I have needed now for 3 days for work. I have spent about 20 hours failing at self diagnose. I do not have any money to take it to a repair shop. However, I would gladly pay pal someone $20 if they can help me repair this? I will share my number or Instant Messenger.
I can not access my computer not through ‘general’ safe mode or ‘f8’ safe mode(Networking/Command Prompt);
Enable VGA does nothing;
Last Known Config or
Directory Services Restore Mode
None of these oprions get me in they just auto reboot. When I attempt to use any safe mode option I get errors like the following:
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS\System32\Drivers\PartMgr.sys
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS\System32\Drivers\VolSnap.sys
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS\System32\DRIVERS\atapi.sys
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS\System32\DRIVERS\disk.sys
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS\System32\DRIVERS\CLASSPND.SYS
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS\System32\DRIVERS\sr.sys
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS\System32\Drivers\Fastfat.sys
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS\System32\Drivers\KSecDD.sys
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS\System32\Drivers\NDIS.sys
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS\System32\Drivers\mup.sys
(there are about 15 of these options; or more).
Then it prompts me to press escape to abort something called SPDT load?
The stop errors are:
0x0000007e(0xc0000005, 0x70f4382,0xf78cf324,0xf78cf020)
The first 2 stop code errors seem to be very broad. I can find no additional information on the additional errors.
The computer is 3 yrs old and has had no issue until the other day. I downloaded a file from a trusted site(Kodak) rebooted the computer and it sent me into this loop auto reboot. It is not running hot, the hard drive is not making strange sounds or smoking. I ran a 9 hour diagnose package that came with the computer. I am not sure what it did but it checked: Thermal/Memory and spent a great deal of time on the harddrive(no errors).
In the xp console I have no clue what I am doing. I tried to repair the boot.ini file, master boot record and other things. It is scary stuff :O. I accidently created 2 new Operating systems(I am asked to select one before loading). I think I did this with bootfix.
There seem to be 2 obvious problems that started when I downloaded and ran a file:
- When I try to load through safe mode I receive those partition errors
- The stop errors. The first 2 stop errors seem very general. The additional ones I can find no information on!
Do I just need to reinstall? Why did this happen? Any thoughts? This loop reboot/safemode/first 2 stop errors seems somewhat common.
20 hours later I still need the files. So it is clear the only way to get into the computer is using console cd.
