My desktop is about a year old. Two weeks ago it started not booting every once in a while. Last few days it will not boot at all.
Spec:
Shuttel XPC with Intel P4 dual core 2.66 and 2 GB memory DDR2 667.
HDD is WD1600AAJS (SATA 2)
I bought it barebone and installed the CPU, DISK, MEM, etc. a year ago.
I have formatted the disk using the WD CD that came with it and then installed XP.
On the rare occasion it will boot, everything looks OK. When I boot using the windows XP CD and I go into recovery console, I am able to access the files on the disk just OK.
I tried already chkdsk /p and /r, I did bootcfg, fixboot and it looks OK. I did not do fixmbr since I got a message saying that my MBR is not standard. I ran a full diagnostics test of the WD data lifeguard diagnostics I downloaded from the website and it found no error.
It will get stuck if I boot from the WD data lifeguard tool CD I got with the drive, and in the case where it did boot from the drive normally, the same WD software complained that the drive is not configured for more than 128 GB and I can see that the partition that I have created using the same software indeed shrank to 128 GB.
Any idea how to fix it?
