z-5500 help
ok i have the z-5500 speakers but the problem is i cant get sound to come out all the speakers at the same time. i can get the center speaker to work in certain modes but not in 6 channel mode. when i test them all they all work correctly, but not in 6 channel mode.
What sound card have you got?
creative soundblaster live 5.1
Hi, check if you have something called CMSS-3D in your sound card settings, if so enable it, this will give you all speakers.
Most music is only in Stereo (2 channel), so will only ocme out of the front left, front right and sub, so best way really is to use PLII Music, this will upmix the 2 channel stereo to kind of 5.1.
