ABIT AN7 booting problems (post code 9F)
Discussion in 'CPU, Motherboards and Memory' started by tortilio, Apr 15, 2010.
  1. tortilio
    tortilio Geek Trainee
    Hello everybody, I'm pretty new to the forum (and to any forum at all!), but I ended up here 'desperately' looking for an answer before going definitively mad!! :confused:
    I also have to confess I'm not so expert about hardware, but I believe I could read and do whatever I might hear! :)
    Well... I'm trying tu run a once working Abit AN7 (Socket A), with a once working AMD Athlon XP 2600+, but whenever I try to turn the system on, it automatically shuts down after a very few seconds (before booting or even loading bios) with the motherboard uttering an alternate sound similar to an emergency siren (although sometimes it not even reaches the time to utter such sound, self shutting down earlier).
    The last post codes shown by the motherboard are the following:
    9a
    98
    99 (that's what it shows when it shuts down)
    9E (and after a handful of seconds from the shutting down, the 99 turns for a very short while in what appears to be a 9E...)
    9F (...than shifting to a permanent 9F)
    The story is pretty long, but these are the clue facts: the motherboard once correctly worked with an Athlon XP 3000+, then I tried to put such CPU on a different (previously checked for compatibility) ASRock K7VT4-4X motherboard without success: power correctly reaching the mobo, but no video signal, nor sounds... Therefore I put the CPU back on the Abit AN7, but the system did not work any more (even here no video signal nor motherboard sounds when powering on)!?
    I then tried putting on the AN7 another CPU (an Athlon XP 2600+, previously finely used on the ASRock mobo), with it working just a 'little better': the system couldn't work with default bios settings loaded - usually self resetting when updating the DMI pool or earlier - but could go with fail safe configuration, and could correctly load Windows in safe mode. After several hardware and bios tests and attempts, I eventually opted for upgrading the bios to the latest version (719), and everything started working correctly.
    At this point (damn myself!!!) I tried to put back on the motherboard its previous CPU (the Athlon Xp 3000+), with it still not working (no video signal). I put the Athlon XP 2600+ having correctly run just a few minutes before back on, and the system started behaving like described at the top!?!
    I think I tried about everything: different graphic cards (with some, the system shuts down even more quickly), different RAM blocks (no difference), disconnecting evry drive, disconnecting and then reconnecting the power supply, clearing the CMOS... the CPU and cooling fan are correctly mounted and running... And I currently have no way to make any attempt to downgrade the bios...
    Another 'funny' fact is that after unsuccesfully trying the 3000+ CPU on the ASRock mobo, not even the previous 2600+ worked any more on it (though behaving a little more ordinarily: video signal and usual starting beeps, the self power down)!
    My questions are: what might ever be wrong? The fact that the system was working with an upgraded bios, before trying to mount the 3000+ CPU makes me suspect it cannot be a matter of hardware... But how to go back??
    I feel pretty discouraged and perplexed, and - as a matter of fact - I now have two previously woking systems currently out of order! :angry:
    Should you need any additional information, just let me know, and please forgive my inexperience with forums, the long post (and moderate experience with hardwrae too...)!
    THANX
