asus A7N8X Deluxe USB2.0 problem
Discussion in 'CPU, Motherboards and Memory' started by caloudika, Jun 6, 2005.
  1. caloudika
    caloudika Geek Trainee
    Hi to all,
    I've got this mobo giving me a hard time with USB2.0
    I'm using Windows XP Pro SP2 and even though the mobo has
    4 incorporated USB ports and another 2 over the expansion bay
    the Device Manager only shows 1 USB port as an active USB2.0 port!!!
    The USB2.0 port is located on the expansion bay, the port next to it
    behaves as USB1.1!!!! :swear:
    All the other show as Standard USB and not as Enhanced (the word
    Enhanced is the key here)
    I have the BIOS correctly setup to support both USB1.1 and 2.0 and I've
    tried all sorts of drivers, both from VIA and ASUS.
    Please give me any suggestions...Thanks :good:
  2. Anti-Trend
    Anti-Trend Nonconformist Geek Staff Member
    USB 2.0 requires a special device driver. It should have been provided on your motherboard's driver CD along with your other motherboard drivers. Alternately, you can get the latest drivers for your chipset straight from NVidia.
  3. caloudika
    Thanks Anti-Geek,
    i'll install the driver and get back to either express my gratitude or vast
    disappointment :D
    quick question though...since i don't have the nvidia driver you suggest, how
    come one port functions properly as USB2.0??
  4. caloudika
    SORRY SORRY...not Anti-Geek...i meant Anti-Trend
  5. caloudika
    Hi all again..
    well, i've tried the latest nvidia chipset drivers and all as suggested...
    still nothing :swear: ...only one of the six usb ports recognized
    as usb 2.0.. :swear: :swear:
    any helpful suggestions??
  6. bobbyk
    bobbyk Big Geek
    You have to manually assign USB 2.0 Drivers to your current devices: Right click on the USB Root device ( In System/Device Manager), go to properties, and update the drivers by manually choosing the USB 2.0 drivers that are now in your System. This will take a while since you have to manually cofigure each USB Root Hub, but thats what I had to do with my setup, too.
