Ati driver help
Discussion in 'Video Cards, Displays and TV Tuners' started by Canadian Weed, Sep 13, 2007.
  1. Canadian Weed
    Canadian Weed Geek Trainee
    I tried to roll back my ati drivers, and even though it said it worked, the 7.9 are still there. I've never had this fail before, so I was wondering if i can simply install 7.7 drivers or do I need to uninstall, then install 7.7?
  2. gazaway
    gazaway Geek Trainee
    When I change drivers I do this:
    Save new drivers on desktop.
    Uninstall old drivers (which requires a restart.)
    Once back up I use a reg cleaner.
    Then install new drivers (which restarts again.)
    Using this process I have never had any problems.
  3. eranga262154
    eranga262154 Geek Trainee
    You can't directly install 7.7, if 7.9 is there. Only the upgrade is the possible. So uninstall the 7.9 driver first and install the 7.7 drivers.
